Cromwell Wittmann Victim to be
101yann
Ille-et-Vilaine, France
KitMaker: 97 posts
Armorama: 97 posts
Posted: Sunday, July 14, 2019 - 02:24 AM UTC
[/quote]
Thank you for that input Yan and so I will have to go back to RSM Gerald Holloway's Cromwell, and it has a more pleasing background. Any photographic help you can offer will be gratefully received.[/quote]
Darren,
unfortunately there are very few pics of Holloway's tank and the front view is the best one I'm aware of... Its rear end does appear in the background in a couple of other shots (showing Dyas's Cromwell) - see below.
FYI at least one crew member was killed : the driver, Lance-Corporal John Trevor-Roper. Shortly after Holloway's tank was KO'd by Wittmann, Captain Dyas's Cromwell was also destroyed just a short distance away while stalking Wittmann. Dyas was blown out of his wagon but suffered from minor injuries and was able to dash across the street to Holloway's tank, grabbed a headset that was hanging out of the tank and tried to alert the other Squadrons at the rear of the column.
In one of his accounts, Dyas recalled he found Holloway's driver was dead inside the tank and had obviously been hit in the face (I'll spare you the gruesome details)...Dyas said he was quite distressed and shocked after that.
PS : there are more / better views of Dunlop's Cromwell in case you change your mind...
Rgds
Yann
CMOT
Staff MemberEditor-in-Chief
KitMaker: 10,954 posts
Armorama: 8,571 posts
Posted: Sunday, July 14, 2019 - 03:13 AM UTC
Thank you as I never realised that was his tank from behind, even in the linked thread I missed that information.
101yann
KitMaker: 97 posts
Armorama: 97 posts
Posted: Sunday, July 14, 2019 - 04:44 AM UTC
Are there amy better pictures of the properties where RSM Gerald Holloway's Cromwell was destroyed outside of?
Unfortunately this spot / area is not well covered and at present the views are restricted to what you can make out in the photos I posted.
Below are a couple of 'then & now' images but again sadly the extension on the side of the property (outlined in green) has changed as have the fences.
Hope this helps a bit
Yann
CMOT
Posted: Sunday, July 14, 2019 - 11:15 PM UTC
I have been picture grabbing.
SpeedyJ
Bangkok, Thailand / ไทย
KitMaker: 1,617 posts
Armorama: 1,150 posts
Posted: Sunday, July 14, 2019 - 11:48 PM UTC
I see Meng released their Toony BMW's
CMOT
Posted: Monday, July 15, 2019 - 01:12 AM UTC
Are front doors in France 6,6 ?
I ask as I need to start working out how big my base need to be and how much of the street will be in the scene.
russamotto
Utah, United States
KitMaker: 3,389 posts
Armorama: 2,054 posts
Posted: Monday, July 15, 2019 - 02:15 AM UTC
Darren, this is an amazing project. I have been following and will continue to do so with interest.
bill_c
MODEL SHIPWRIGHTS
KitMaker: 10,553 posts
Armorama: 8,109 posts
Posted: Monday, July 15, 2019 - 02:56 AM UTC
Looks like some changes were made to the house behind the Cromwell: the side room seems to have been extended and the "shed" next to the house demolished.
CMOT
Posted: Monday, July 15, 2019 - 05:12 AM UTC
The white building with the three dorma windows would appear to be the same as it was during the war with the addition of a new build on the right. The property on the left has had the arched roof removed as evidenced by the filler line on the brickwork of the building, a right to left sloping roof has then been cut into the bare brick structure. I believe the wall with the railings is original with new railings installed and a cement shim over that brickwork; I believe the railings on the property to the left again may be the original iron railings. The pavement section looks very wide as it does in the period pictures; I have no idea as to why this is the case. I also note a telegraph pole has been removed and that will have to be best guess for location.
CMOT
Posted: Monday, July 15, 2019 - 05:26 AM UTC
I believe the image below clears up the property change.
russamotto
Utah, United States
Posted: Monday, July 15, 2019 - 08:27 AM UTC
If these are farm houses, or were, the pavement area could originally be to allow wagons or vehicles access to park and load or unload and keep the main roadway clear. The writing on the side of the house might give more details.
Frenchy
Rhone, France
KitMaker: 12,719 posts
Armorama: 12,507 posts
Posted: Monday, July 15, 2019 - 09:18 AM UTC
If you're talking about this :
I guess it's just an typical example of painted advertising popular in these years. This one appears to be for a clothing brand or more probably a clothing shop. I'm afraid it has nothing to do with the house it's painted on.
H.P.
babaoriley
KitMaker: 195 posts
Armorama: 179 posts
Posted: Monday, July 15, 2019 - 10:06 AM UTC
RB makes it. Sorry,I forgot to add that important tidbit.
Alum barrel with a three part brass brake. Impressive.
J
Thanks. RB calls it the 75mm bored-out version, but so far as I know it should look the same as the six-pounder externally, at least in 1/35 scale. There is at least one U.S. source, of course it's out of stock....
Aaaaaand Sprue Bros. has it back and stock and it's on sale. Or as I explained it to my wife, it's fate, and you can't fight fate. So I ordered two.
Removed by original poster on 07/15/19 - 22:15:51 (GMT).
JohnTapsell
KitMaker: 227 posts
Armorama: 226 posts
Posted: Monday, July 15, 2019 - 10:17 AM UTC
Note that some of the Cromwells have the all-round vision cupola - some Cromwells did at this point whilst others still had the older style.
John
CMOT
Posted: Monday, July 15, 2019 - 11:03 AM UTC
John
I have both styles ready John and will likely go for the three periscope style.
CMOT
Posted: Thursday, July 18, 2019 - 04:46 AM UTC
Can anyone provide me with the details on a door height in France during this period. Once I have that I can start laying out the diorama base, if I cannot get that info I am going to work on 6,6 for the door.
CMOT
Posted: Tuesday, July 23, 2019 - 01:49 AM UTC
Does the layout below look right ?
Sean50
Manche, France
KitMaker: 340 posts
Armorama: 328 posts
Posted: Tuesday, July 23, 2019 - 07:30 AM UTC
Hello Darren
It may be a little late but anyway…. My own doorway (early 19th Century) is about 2m, so 6'6". The door itself is about 1,95m.
I live about 45 minutes from Villers Bocage, so close enough for a comparison. It's just a straightforward door, no skylight or anything
I would just add though that there may be a difference between rural (mine) and urban houses, even those on the edge of a town like Villers Bocage.
Sean
CMOT
Posted: Tuesday, July 23, 2019 - 07:48 AM UTC
Sean that is of great use as I have not started the buildings yet and so thank you for your input.
TopSmith
KitMaker: 1,742 posts
Armorama: 1,658 posts
Posted: Tuesday, July 23, 2019 - 01:18 PM UTC
For those who are trying to get a Cromwell "D type deck" in the US, Wanamaker Hobbies carry Accurate Armor.
CMOT
Posted: Tuesday, July 23, 2019 - 08:35 PM UTC
I will add to that Greg that the hatches do not fit the holes but the kit ones are a perfect fit. This does require the handle detail is cut off and replaced with wire.
russamotto
Utah, United States
Posted: Friday, July 26, 2019 - 01:22 AM UTC
Don't know if this helps at all, but I found this link while looking through a page at Missing Lynx.
http://www.christopherlong.co.uk/oth/farmstruct.html
I would think construction would be fairly consistent as to door sizes.
CMOT
Posted: Friday, July 26, 2019 - 01:53 AM UTC
Thank you Russ; I am unsure if rural buildings can be used as a direct comparison, but I found it interesting. The other plus is that rural building tend to be more often used in scenes than town buildings.
