Hello Bob, thank you for the encouraging words, I appreciate them and...I need them too.
Painting the road wheels attached to the lower hull section is not as difficult as I thought it was. Usually I paint them separately and on top of a tooth pick. A friend of mine on Benelux Kitmaker who loves to build Sherman tanks, paints his road wheels when put in place, and I just wanted to see if I could do it the same way.
But I did not glue them, so they are workable. I painted the rubber in acrylic mat black, thinned with 90 % water, diluted to let the paint find its way around the steel of the wheels. I repeted this three times to cover entirely the surface. This way of working was very easy because it was the running paint that did the job. Then I drybrushed with a mix of mat black and mat white, to make the damage in the rubber more visible (I carved the rubber to add reality).
For the weathering (still in progress) I do the usual stuff.
I have more future projects planned, but I will only start one. Problem : I just can't decide !
- Bronco Comet Tank 1/35,
- Tristar 20mm Flak with Waffen SS crew 1/35,
- Dragon Panther (Normandy) 1/35,
- Tristar Marder III...
But now I want to finish this Stuart, placed on a small diorama with a Tunesian house section, and a couple of figures.
I hope I gave you a clear answer about the wheels my friend.
Next update coming up soon.
I still have to finish the gear of the Stuart too, and the .30, and a lot more...
G.
