However there is one thing I really don’t understand about the rear end of the RammTiger which is why the huge rear door? Entry I would have thought, would be easier by going under and up, or am I wrong? The driver and gunner would enter via the front or am I wrong? There is no ammo so what was the thought behind it on the blueprints?
Hmmmm....my thoughts on the back end: The large doors would allow access to the engine deck. Granted, the mechanics certainly couldn't pull a "pack" with the Ramm hull in place (something Kim worked out with the access panel on top of the hull), but general maintenance? Larger door, more "maneuver" room, more light in? I'm thinking "general maintenance" because the distance from the engine deck to hull top is limited...crawlspace more likely. Which leads me to now wonder if there's enough room, as is, for the engine access panel(s) to open.
Based on the way this one is building, there
could be room for someone to slip between the hull and the tank's back end....certainly not a Sergeant Schultz tho!
Access to the "conning tower" would either be through the top hatch, or through the hull's rear doors and then the conning tower's rear hatch.
The driver and gunner would have ample room to go through the hull's large front opening (or under the snout) and into their respective positions.
I am also impressed with the quality of the scratch building that has been exhibited in this campaign, which despite being a relatively easy build we have managed to make it a lot harder than it should have been, overcoming problems of our own making
How right you are. I think originally, most probably believed that all you had to do was build an angled box and plop it on top of a tank. Technically, that's all that needs to be done. But....some of the discussions during the various builds have brought out...thoughts, considerations, and questions.
HOW would this work?
HOW could this work? We've gone from a pretty straight forward build to builds that are trying to answer some of these ponderings. I can simply use your build as proof-positive....you've certainly taken your's six steps ahead of mine!
Every build I've seen of this vehicle (here and elsewhere) has been a
modification....they've added an armored hull to the chassis and created a ram. You on the other hand, have taken an idea, put it to paper, built a mock up (I'll use your first one as that example), modified the plans, found the weakness', and now have a "production" vehicle being produced. Hmmm...sense some similarities?
Oh, forgot to mention....the "double-step" on the back end is two strands of very thin wire twisted pretty tight by hand to create a "wire rope," and two pieces of scrap diamond plate that were drilled at each end....wire ladder basically....much like the cab steps of a lot of tactical vehicles.
I'm at a juncture in this build where I either go forward full-blast, or hang tight until I get back from Germany. I don't want to get started on one step only to have to stop for my trip. Most I can see doing between now and Thursday is
maybe spraying the inside of the hull in red-brown. I've got too many things to get done and gather up before I fly out Friday morning.
Mike
