Today I started with step 4 of the AFV club instruction sheet. This step was quite simple and no major issues were encountered. I first attached parts A20 and A21 that I left off in step 3. I believe that this was a good choice since I can see many people getting frustrated in trying to maintain proper alignment of the wheel struts in step 3. Parts A17-19 are a little tricky to get square too each other. I decided to add parts A18 and A19 to the hull first and then align part A18 on top. To get the parts square I used a pair of tweezers to hold parts A18 and A19 square while attaching part A18. (Figure 1).
Figure 1. Step 4
Step 5 was very easy and quick, there was some minor flash cleanup on all parts, especially parts A13 and A14 (Figure 2).
Figure 2. Step 5
I decided to step away from the normal procedure here and started to clean up the resin upper hull from Real Models. I was initially concerned that I would cut to close to the hull and really mess things up. I started by using my dremel cutting wheel on the lowest setting and cutting the pour block down to about the width of a pencil lead. Once I had a real thin sliver of resin remaining I used my Xacto saw and cut off the remaining resin. Some dry fitting revealed that the only thing I would need to-do for a flush fit is to cut away the pour blocks on the Real Model’s upper hull part 1. There was a small air bubble that needed filling just behind the turret opening on the upper hull, which I filled with a bit of super glue and accelerator. Figures 3 & 4 shows the upper hull part 1 with the resin pour blocks removed.
Figure 3. Upper Hull part 1, left side.
Figure 4. Upper Hull part 1, right side.
I’m now contemplating step 6 in the AFV club instructions as well as looking at Real Models resin wheels. Looking at them side by side (Figure 5), there is no distinguishable difference between the two. Looking at Real Models instruction sheet you can see that at one point the kit was built with the AFV club tires and then switched to resin (see sheet two of the real model instructions). I think that I will use AFV clubs tires with the photo etch provided by Real Model.
Figure 5. Tire Comparison.
Tankleader's BlogTanks
Andy
