Thanks for looking and feel free to comment.
I really hope this kit works out well, it looks like you have ALOT of money invested in it
Yes , I agree.Good luck and I look forward to the build. thanks , Bob
Nicholas;
The tank had a HL 210 engine, so you should use part Y-9 rather than Y-7. That's assuming that you have a Y-9 in your box. Dragon sometimes clip off unused parts.
I don't like the look of those bases for the TMD S-mines, they look square whereas the real ones had a pointed front. See the sprue part G-3 which is correct.
The tank had the frames on the rear hull, so you'll have to cut off the molded-on hinges and use parts G-29 and G-30. I have clipped out some of the instructions from the "Wittman" kit which explain what to do.
David
Nick:
Here's a whole bunch of photos of 312.
It's clear the tank had the old Tiger (P) flat mantlet, so use part A7.
The tank in the photos is on service and has its Feifels removed. The Fehrmann kit was tooled to correctly represent the welded mounts of missing Feifels, so you could copy the photos. But if you want to use your resin Feifels and model the tank earlier in its life, go ahead, as they are the correct type.
The kit gives you 2 alternative ways to build the engine hatch, you should use this one:
The bad news is: the tank had the newer road wheels with 12 bolts evenly spaced. And the kit doesn't include the track cable on the left hand side, just the empty mounts.
David
nice build so far!
is dragon actually going to release a normal tiger 1 early just like tamiya?
regards
Jens![]()
Did you file off the nubs on the rear towing pintle holders, as specified in the instructions?
David
Yes, the top should slant more... can that also be sanded off?
David
