Morning Gents,
Here's a pic of the Instrument Panel I mentioned in the post above:
If I had picked the difference up earlier I might have made an effort to alter the face, I still might lol, lol.
Here's the kit part added to the front plate with the fire extinguisher, grab handle and drivers wheel fitted. I have trimmed of the extra dial on the instrument panel and shaved off one of the knobs that doesn't belong.
I did some work on the rear plate this morning, Ah PE lol, lol. so far so good though:
On fitting the rear stowage you need to add parts CA, CB, U26, DV and P9
These fit onto the bulk stowage which is why the fit needs to be correct. Also on the buld stowage if you look at the next pic you will see that the water cans are supported from below by a bracket. Haven't got that far yet but something to remember vwhen you fit the stowage.
There is not too much work to do on the front and I've made a start by fitting parts DC and DD. If you're using the fron stowage then part DD and DP are probably not required but I hollowed out the botton on the tarp so that it will fit over them when in place.
Al
