I like to start project like this by doing the major surgery first, so that there's no turning back. I began by removing the protrusions from the upper portion of the rear hull plate. This is one of the most noticable errors in the kit-there should be two layers of spaced armor here onto which the rear hull stowage boxes are mounted. (not pictured)
I then moved on to the upper hull, removing the water barrier housing from the rear, the periscopes, and the armor plating around the driver's hatch. I slightly rounded the left side armor plate, and added bolt heads to the inboard side of the left and right side armor plates. They are simply shaved off of unused kit pieces.
The remaining water barrier housing on the hull would be a monumental task to remove, so I left it. It will be hidden for the most part by tools, stowage, etc.
Step 1:
