Thanks guys, I appreciate all the comments and the interest. Nice links too, there are some great pictures of JS-2s in action and there was another link in the post that led to more great pics. Thanks!
I spent most of the day on my workbench yesterday alternating work between the JS-2 and the Char B1 bis.
I've completed most of steps 3, 4, 5, 9, 10, 11, 12 and 13. There are a few more detail parts that need to be added, but they will go on after painting.
The hull was pretty easy to mate up once I dry fitted a couple of times and came up with the game plan for applying the glue and keeping the parts flush and aligned. I started by placing them together upside down, put a little liquid cement where the connecting tabs and locating circles were, gave that just a sec to solidify then ran cement all along the seam, flipped it all over then carefully held the front and back halves together to get a nice, solid joint. worked like a champ! Just be careful though as you want the upper hull surfaces to be level with each other. As long as you keep them butted up together firmly, this won't be a problem.
At this point you need to decide which scheme you're going with so you can drill the holes for the headlamp and the horn. If you're doing yours as one the one that served with the Polish 4th Heavy Tank Regiment then you'll need the holes right side (left if looking from underneath). All other variants have them mounted on the left (right if looking from underneath) so be careful! Also think through the angle you need to drill the holes at as the surfaces they're mounted on are at an angle. You'll want the hole for the headlamp to be completely vertical, the hole for horn should be perpendicular to the angled surface. Make sense?
Here are a series of photos from this morning of the almost completed hull and running gear. I still need to install the mud scraper for the drive sprockets, and various tools. I'm going with the Aber engine grill set, so I have some modifications to do to remove the molded on hinges which don't look at all like the real thing. The Aber set will rectify that although I have to make my own hinge wires as they're not provided. More on that in a later build log installment.
Today the game plan is to build the turret and install the Aber D-25T 122mm gun.
