Great looking work, I've got a question for you. Is that the Testors Enamel colors you're using for the dot/fading on the camo? If so, how did you get it to blend so well? I just tried it on a Panther (basic Model Master Sandgelb finish) and it made a bit of a mess of the base paint job (darkened it, streaks of different colors). Thanks for any input or tips you can provide.
Sean,
Yes, I used either Testors regular or Model Master enamel colors for the dot filters and fading. The key to getting it to blend is selection of colors and working in small sections at a time. If the dots are allowed to sit too long, they will start to "harden" and become very difficult to blend properly. To blend them, you have to use repeated strokes of a thinner dampened brush, continuing to work with them until they virtually disappear. The goal here is to produce a very subtle shade variation, so if you're seeing vivid streaks you've either used too much paint in your dots and/or didn't repeat the strokes enough. The dots need to be fairly small as well, some of the colors such as white, yellow, red, etc. are very powerful in small quantities so a little goes a very long way. Here's an example of what I mean by the strokes required:
As far as the issue of paint darkening goes, this may be driven by your choice of colors for the filters/washes and also whether or not you lightened your base coat to compensate. I will typically lighten the base coat for a Dunkelgelb or similar color by adding anywhere from 20% to 50% Light Gray (I prefer that vs. White) as a means to compensate for what I know will happen during the weathering process. HTH!
