Did some work over the weekend. I ended up using the Taymia M4A3 hull (which is the same in the M4 kit anyway), and im not concerned about the accuracy of the underside, as I plan on mounting the finished model on a base anyway.
I went with a early cast nose from Academy M10 kit, as I saw several pictures with M4s with this style nose, and thought it would be a nice change from the usual. However the dozer will cover most of it up, and ive now discovered that the dozer is molded to fit the later style “sharp” cast nose…so I may have to modify the dozer parts a bit (later).
After attaching the nose, I put on the plates behind the drive sprocket, which as you can see don’t exactly line up with the nose (I don’t think they do on the taymia “late” cast nose either). Simple fix was to ream out the hole that the axle slips through, and cut off the peg on the rear so the whole plate can slide up just a bit. A very small gap is between the plate and nose, but that is later filled with some plastic strip.
Before and after shots:
You may see in the background some of the bogies assembled. I stole these from Dragons new M4A1 76mm, as they are very nicely detailed and assemble easy. I will use skids from Aber PE set, and drill the missing holes at the front of each unit. More on that later…
Speaking of tranny covers (differential cover), I have yet to decide which bolt style I should use. I have the early exposed bolts from Dragons M4A1 early, and several sets of the recessed bolts. Im leaning toward the recessed bolts
Continuing work on the lower hull, I mounted the rear plate and bits from the taymia kit. I did shave off the handle from the engine access doors, to be replaced with wire in the near future. I had originally built and detailed the air cleaners, but then realized that the exhaust trunking will completely cover them so no point in mounting them or detailing any of the area up under the hull.
Ok, now for the upper hull….as Greg pointed out, the welds are horrible. I was starting to wonder as pictures I found I could not see any seams or welds on the front plate. So I cut some plastic strip and laid it into the bead, spread Tenax over it, then shaped and pushed it into the grove using a small flat-head screwdriver. I haven’t test painted yet, but im hoping that they will look just like the flowing flush style welds on a sherman. Now it sounds like I may be rebuilding a antenna pot too…hey, that’s what modeling is all about.
Well that is it for now. Maybe tonight will bring some more time behind the bench…
Andy
