Here is something at the other end of the scale.Same frame,size,color etc... but the main subject is in the foreground.Depth has been achieved and the main subject highlighted by simply fuzzing things up a bit.It also adds kind of a dreamlike quality to the whole thing.
The license on the car adds just enough info to put the whole thing in context.
Damn! this is fun stuff to do.
Finishing up the Albatros diorama
dolly15
Quebec, Canada
KitMaker: 8,227 posts
Armorama: 1,975 posts
Posted: Tuesday, March 03, 2009 - 05:14 AM UTC
dolly15
Quebec, Canada
Posted: Wednesday, March 04, 2009 - 10:55 AM UTC
dolly15
Quebec, Canada
Posted: Wednesday, March 04, 2009 - 12:55 PM UTC
dolly15
Quebec, Canada
Posted: Thursday, March 05, 2009 - 04:04 AM UTC
dolly15
Quebec, Canada
Posted: Thursday, March 05, 2009 - 04:25 AM UTC
The young need not bother to read......
I know,I know it is not an airplane,car or figure, but Photoshop's new poster feature makes for some great looking book titles and it has got me to thinking that maybe sometime in the future, I may do a limited run of pictures and text of all my diorama's (only4),and put them in book form for friends and family.This would not be a "How to..." book but just for fun.
I understand that there are internet sites out there that will bind your stuff in book form ,on a very limited run basis,and are not too expensive.
I am especially thinking about the large diorama and RR layout guys that don't have museums or such to take their work.I know that nothing survives forever but I have witnessed some very beautiful stuff being broken up and put in the trash when the builder passes on to the "happy hunting ground".Individual pictures and such are nice but a book of your stuff and text in your own words would really make for a nice legacy for those who come after you.
dolly15
Quebec, Canada
Posted: Friday, March 06, 2009 - 03:30 AM UTC
dolly15
Quebec, Canada
Posted: Saturday, March 07, 2009 - 04:15 AM UTC
dioman13
Indiana, United States
KitMaker: 2,184 posts
Armorama: 1,468 posts
Posted: Saturday, March 07, 2009 - 05:10 AM UTC
John, very good work. I've been following your build and it has been interesting to say the least. I build dio's myself and was smiling when the pic came up of the interior of the barn with the bird nest and marking on the wall, they must mark their territory as we do. Very fine job you have accomplished.
dolly15
Quebec, Canada
Posted: Sunday, March 08, 2009 - 03:15 AM UTC
dolly15
Quebec, Canada
Posted: Sunday, March 08, 2009 - 03:39 AM UTC
Surprise it's back to square one!
So you thought that it was almost finished?
Well now it is time for final assembly.Starting back at the bare plywood stage it is now time to permanently screw and glue things down.The plywood was lacquered last summer on both sides and edges to make it waterproof ,which is very important because a lot of the next steps require the use of lots of water.
I have positioned the hangar for a unobstructed ,clear view in to what will be the open hangar doors.
The landscaping is divided at the hangars corners into four parts for ease of assembly.Each part will be finished and then screwed down to the base.
I have arranged it so that there will be four separate areas of interest ,almost like four dioramas in one.When viewing one area I have tried to plan it so the viewer will not be distracted by the other three.For example the view of the crashed Albatros outside, is blocked by the L/H open hangar door.When viewing the crashed Albatros from the side it is not possible to view the backyard of the hangar.The R/H hangar wall is plexiglass and affords another unrestricted view into the hangar.In real life another hangar bay would have been built here ,so this is basically a compromise between reality and fantasy.(artistic license ,if you will)
Now it is on to temporarily screwing down the four landscaping panels and the final positioning of the hangar.
dolly15
Quebec, Canada
Posted: Sunday, March 08, 2009 - 12:44 PM UTC
dolly15
Quebec, Canada
Posted: Tuesday, March 10, 2009 - 02:35 AM UTC
Another pic
dolly15
Quebec, Canada
Posted: Tuesday, March 10, 2009 - 03:34 AM UTC
I was originally going to screw the landscaping panels down from underneath the plywood base but that proved to be unpractical.Instead I drilled a hole down through both panels,and screwed down the panel from the top.I will cover the screw heads using rocks or grass etc... I identified the holes under the plywood panels as "screws above" so that if in future if it is to be taken apart they will be able to locate the screws.
The hanger itself was screwed down the same way, from below, and holes added to the plywood where the wheels of the aircraft are bolted down ,so that the Albatros could be removed from the hangar separately if need be.
The landscaping panels are of course removable so that each can be finished individually and then finally re-installed.The now visible seams will be filled as required and blended in to become invisible.
dolly15
Quebec, Canada
Posted: Tuesday, March 10, 2009 - 11:45 AM UTC
dolly15
Quebec, Canada
Posted: Wednesday, March 11, 2009 - 03:51 AM UTC
Something different!
I took a whole bunch of new pics today while I still have easy access to the
hangar windows.I haven't yet had a chance to edit out the bad ones.I removed the frames and shot through the windows from different angles.I am also experimenting with doing photographic type dioramas and vignettes and setting them in formal type frames.This is a lot of fun and opens a whole new dimensions to doing dioramas.One storyboard diorama can be broken down into hundreds of smaller vignettes.
dolly15
Quebec, Canada
Posted: Wednesday, March 11, 2009 - 05:23 AM UTC
dolly15
Quebec, Canada
Posted: Wednesday, March 11, 2009 - 09:25 AM UTC
"Hanging The Left Hand Aileron"Vignette
This is a good example of a storyboard vignette.The aileron on the workbench and the ladder pretty much tell the story.The floorboards give a nice 3d effect and perspective that helps lead the viewers to the sign of human presence, as represented by the boots. For those who are really knowledgeable about uniforms, the hat indicates that this is more than likely, a German hangar of WW1.
dolly15
Quebec, Canada
Posted: Thursday, March 12, 2009 - 03:19 AM UTC
dolly15
Quebec, Canada
Posted: Thursday, March 12, 2009 - 04:56 AM UTC
Most of these shots will be lost once the diorama is finished.I took a few days out from building to play with the camera.I really don't know that much about cameras so I take lots of shots at different settings and then delete what I don't want.Using film would have forced me to "read the instructions"(as my dad would always tell me) a long time ago or go broke buying film.
Digital cameras allows guys like me to fool around and really not know what they are doing . I would rather build than read instructions anyway.
dolly15
Quebec, Canada
Posted: Friday, March 13, 2009 - 03:51 AM UTC
dolly15
Quebec, Canada
Posted: Friday, March 13, 2009 - 12:14 PM UTC
The lane out back.
I am starting to make a lane way(dirt road) out back of the hangar .Here I have started to build up the raised portion that normally lies between the tire tracks.I have used ordinary sand for this,sprayed with alcohol as a water tension breaker and then soaked with the usual 75/25 water and white glue mix.Once dry I will add the fine sand,earth ,vegetation and a few rocks here and there.
Next I covered the sand mound with the earth and measured the dirt roads width using the Ford T truck as a guide.I then covered the the width of the road with the earth,sprayed on the alcohol ,and put on the water /glue mix ,drop by drop. I then took one of the trucks spare tires and rolled it down the dirt road to create a few tracks.The road still looks a little whitish as the white glue hasn't dried yet.
dolly15
Quebec, Canada
Posted: Friday, March 13, 2009 - 12:35 PM UTC
Hunter6
Missouri, United States
KitMaker: 76 posts
Armorama: 70 posts
KitMaker: 76 posts
Armorama: 70 posts
Posted: Friday, March 13, 2009 - 01:07 PM UTC
I am.........amazed! I envy your talent and imagination.
Cordially,
Dennis
Cordially,
Dennis
dolly15
Quebec, Canada
Posted: Saturday, March 14, 2009 - 02:32 AM UTC
dolly15
Quebec, Canada
Posted: Sunday, March 15, 2009 - 02:25 AM UTC
Working on the composition.
