KitMaker: 365 posts
Armorama: 283 posts
Posted: Sunday, April 26, 2009 - 09:20 AM UTC
Gino, thanks for your comments, once again your input is extremely welcome. When it comes to stuff like this your a font of knowledge. And on that note, you don't happen to have know where I can get dimensions for the rear rack APU, I'm trying to scratchbuild one from photos! not working out very well.
thanks
KitMaker: 365 posts
Armorama: 283 posts
Posted: Thursday, May 21, 2009 - 10:57 PM UTC
Ok, been busy trying to scratchbuild the EAPU for my Abrams here it is at the moment. Thanks to Olivier Carneau for the dimensions.
Also scratchbuilt the stowage basket for the side of Abrams.
Again Comments welcomed.
Also, looking to start on the groundwork for this:-
Can anyone suggest the best way to start and what to use for the water.....
Tried using fine sand and burnt sienna/elmers - water mix. Colour or texture doesn't look right...
I'm new to doing dio's so any help would be grateful..
thanks
Paul.
KitMaker: 1,548 posts
Armorama: 1,407 posts
Posted: Wednesday, May 27, 2009 - 04:35 AM UTC
Nice work mate, any progress?
KitMaker: 365 posts
Armorama: 283 posts
Posted: Wednesday, May 27, 2009 - 09:39 AM UTC
Martyn, thanks for comments.
Done some groundwork but I'm not completely happy with it. Here are the pictures below. (I think I'm expecting too much for my first dio attempt!!)
Any comments and suggestions gratefully accepted.
(ignore the toy skittles in the background, will get some outdoor photos tomorrow.)
Posted: Wednesday, May 27, 2009 - 11:28 AM UTC
NIce work Paul, I rather like the ground work.
KitMaker: 365 posts
Armorama: 283 posts
Posted: Thursday, May 28, 2009 - 02:18 AM UTC
thanks Martyn, just got some more left to do then gotta figure out the best way to do the water!
Maryland, United States
KitMaker: 1,132 posts
Armorama: 1,123 posts
Posted: Thursday, May 28, 2009 - 05:18 AM UTC
Excellent groundwork! Looking good, you've got a nice start to this one! Like it being based on a photo, that's neat!
Thanks for sharing! Cheers -
Tim
Current projects:
AFV 8.8cm Flak 18 (35088) (paint stage)
Academy Warrior MCV (OIF) (final touches...then paint)
Next up:
Revell A-6E Intruder (?)
KitMaker: 365 posts
Armorama: 283 posts
Posted: Thursday, May 28, 2009 - 09:23 AM UTC
ok, been doing some work on the Abrams, and looking at my reference picture the abrams has the big foot tracks.
Does anyone know where I can get these from or a cheap alternative to them?
Posted: Thursday, May 28, 2009 - 10:44 AM UTC
AFV CLUB do a set for around £12
KitMaker: 365 posts
Armorama: 283 posts
Posted: Thursday, May 28, 2009 - 11:06 AM UTC
yeah, i've seen them, they just look a little bit fiddly for me! plus only part of the tracks are going to be visible, so thought if I could do it any other way then this would save money!!
KitMaker: 365 posts
Armorama: 283 posts
Posted: Monday, June 01, 2009 - 10:15 AM UTC
OK, took some photos outside today.
This one is the start of the groundwork for the bradley dio..
Again, any comments/criticisms/advice etc. welcome
KitMaker: 365 posts
Armorama: 283 posts
Posted: Thursday, June 11, 2009 - 09:38 AM UTC
Ok done some more groundwork on the Abrams dio
The plan now is to wait until the filler is dry, then paint a mud colour browns mixed with olive drab etc.....
Then add a few layers of clear caulk to create the water effect.
Also I've adjusted the rear end of the tank, (cut it of!!) this will make the sinking hull look more realistic. (I Hope)
Posted: Thursday, June 11, 2009 - 02:20 PM UTC
Nice work mate; looking good.
KitMaker: 100 posts
Armorama: 78 posts
Posted: Thursday, June 11, 2009 - 03:25 PM UTC
be careful about using clear caulking, as sometimes it does not dry entirely clear, and can tend to look like, well, clear caulk. Have you considered using resin as the base water, then perhaps using caulking for waves/current, etc.? Whatever you decide on , make sure to test it first to make sure it turns out the way you want it.
Only two defining forces have ever offered to die for you. Jesus Christ and the American soldier. One died for your soul; the other for your freedom.
A liberal CNN reporter once asked a Marine sniper "What do you feel when you shoot your target?" The
KitMaker: 365 posts
Armorama: 283 posts
Posted: Thursday, June 11, 2009 - 08:45 PM UTC
Thanks Martyn,
Matthew, I have considered using resin but I'm concerned with the heat issue, I don't want to melt my tank once all the stowage is on! I intend to try the caulk on a sample piece of groundwork, so I can get the colour right as well.
Gbarksdale's dio at this link has used the caulk method for his water pictures 2 & 3 and this is what I'm gonna aim for.
https://armorama.kitmaker.net/forums/140399&page=1 You'll see in previous posts that what I'm trying to go for the water is calm and shows no ripples. Also for the amount of water I need, caulk is the cheaper method.
Next up is to sort out the stowage gear for the back of the tank.
Thanks for your comments guys, more photos when I've had time to work on model.
Ohio, United States
KitMaker: 516 posts
Armorama: 391 posts
Posted: Friday, June 12, 2009 - 08:14 AM UTC
Paul,
That dio is looking great. I hope my first military dio looks half as good. When I have done water I have used clear acrylic and added color and dirt to it. However, I never had to create as much water surface as you will.
I really like idea you are using. Combines my two of my more favorite things...tanks and off-roading!
Tony
On the Bench:
M2A3 Bradley
It's not a sin to get knocked down;It's a sin to stay down
"Master Chief Boatswains Mate Carl Brashear"
KitMaker: 365 posts
Armorama: 283 posts
Posted: Friday, June 12, 2009 - 08:26 AM UTC
Tony:
Thanks for the comments, believe it or not this is my first attempt at dios!! After seeing all the excellent an realistic looking dios on this site I thought I'd try it for myself.
Struggling with a few things but I'm giving it a go.
KitMaker: 365 posts
Armorama: 283 posts
Posted: Monday, June 22, 2009 - 10:47 PM UTC
ok, started the stowage on my abrams,
I've also started the water effect on the base (photo's to come) at the moment I'm happy with the result, but i think it needs some colour, currently its a semi-translucent look.
Any suggestions on colours would be helpful. I was going for a dirty green with a hint brown!
KitMaker: 365 posts
Armorama: 283 posts
Posted: Thursday, June 25, 2009 - 09:43 AM UTC
Couple more updates to the stowage. (I know it doesn't look like I've done much since the last update, but its better than nothing.
One thing I'm struggling on is what to place in the stowage basket next to the EAPU?
Posted: Thursday, June 25, 2009 - 09:50 AM UTC
Nice workmate.
KitMaker: 365 posts
Armorama: 283 posts
Posted: Wednesday, July 08, 2009 - 04:50 AM UTC
Thanks Martyn,
I've done a little more to the abrams, had to scratch a new fender as I've lost the original!
KitMaker: 365 posts
Armorama: 283 posts
Posted: Sunday, August 09, 2009 - 09:11 AM UTC
Ok it's been a while. Did some work on the model the past few nights mainly groundwork.
Any comments / suggestions are welcome.
Thanks for viewing Paul.
KitMaker: 1,019 posts
Armorama: 933 posts
Posted: Wednesday, August 12, 2009 - 03:12 AM UTC
Great work Paul!
As for water I use Crystal Resin. It dries totally clear and gives good effects although you have to make sure the area is sealed sufficently. I've had that problem in the past and found a little gap i didn't see and watched in horror as my river seeps out of the side of the terrain peice!
I really like the scene your trying to recreate as well, it's very interesting. I've seen a few great swamped or abandoned vechile dioramas that follow a similar setup.
For advice and tips on water effects I would reccommend the book by Xtreme Modelling, Elements in Combat 1.
I have the second book in this series "frozen Hell" that covers snow and winter effects. They are great books and really nice reads too.
KitMaker: 365 posts
Armorama: 283 posts
Posted: Sunday, August 23, 2009 - 09:52 AM UTC
Ok, added the tank body, and the surrounding mud, just gotta paint and weather the groundwork then add the water...
KitMaker: 7 posts
Armorama: 3 posts
Posted: Sunday, August 23, 2009 - 10:58 AM UTC
This looks really good, im hoping to start a dio soon with water effects so i'll be watching this closely!
