hey Guy thanks! but as you know it from your own work, a diorama is FIRST a good idea!
Claude, there are things in life with whom you have to be both very brutal and very caring in order to succeed, the *timing* is the thing
You know Charles I had first designed the dio so that indeed could remove easily the child for transport purposes. the problem is that he's standing on an angle, and I will have to put some filler above the hole on the hull in order for it to be looking realistic whne I will be finished.
I thought of making a mould of that child but don't have the competences sadly..
But wait, I will have a further 2 or 3 kids to sculpt for the Masséna and will *try* to get some decent moulds out of them!
thank you Martyn! Water is not *that* difficult, you jyst need a bit of time ahead!
Chris, really this is a matter of taking risks to achieve your goals! If i had failed, what would it be? bah, just 1 month worth of week- evenings, and i could still have salvaged the kid for something else. it was worthy to take the risk!
Alec thank you -must say I thought your first work was very impressive and I wait for the second- About the sheer work, that's all down to the same question, "are you in a hurry ?" I am not.
When i die I want the people to say "well he did very few dioramas, but those were good ones"
And then in order to die in the most possible amount of time, think about wearing your gasmask whenever using resin based stuff.
(on the left the Archangel diorama, on the right my wife's bicycle)
Acrylic gel carefully applied with a brush to create the waves! remember the ration paint/gel must not be above 5% or you screw the thing!!
Don't try and think too much about it, just try to *be* the water and you will see where to put the foam -alternatively google for sea pics
And here's the foam -first coated, not dried up
still looks a bit crap methinks..
