Challenger 2 operation telic.
newfish
KitMaker: 2,329 posts
Armorama: 2,110 posts
Posted: Sunday, April 12, 2009 - 02:17 AM UTC
Niel great work its coming on great!
punisher2-2
KitMaker: 50 posts
Armorama: 44 posts
Posted: Sunday, April 12, 2009 - 09:26 AM UTC
This is a great build! I'm looking forward to more progress posts and pics.
SIRNEIL
KitMaker: 658 posts
Armorama: 599 posts
Posted: Sunday, April 12, 2009 - 10:10 AM UTC
Hi ian
Most of the challengers that took part in op telic look like the camo netting was kept inside some sort of camouflaged bag that was then strapped to the hull so you wouldn't see the type of netting that you are refering to.......
Hi jim
Your still onboard after all this time?
cheers jim
Hello evan
Thank's for the comments,your wish is my command!!!!!!!!!!!!!!!
I have finally given the chally a coat of of johnsons klear and all the decals are on using micro sol/set.
The camo netting bag (i think thats what it is) the big long white thingy that i made earlier will be left to dry overnight.Once it has dried i will then give it a few coats of mr.surfacer 500 just to help smooth the material....
Neil..................
one thing I have seen done it to sprinkle dried herbs (can't remember the type!) over the netting to give some texture
Hi jim
Hello evan
spitfire303
KitMaker: 1,437 posts
Armorama: 1,406 posts
Posted: Sunday, April 12, 2009 - 10:46 AM UTC
Looking very good Neil. The smaller chipping is definitely better. Great work!
spit
spit
newfish
Posted: Sunday, April 12, 2009 - 11:33 AM UTC
Hi jim
Your still onboard after all this time? cheers jim
Indeed I am!
and have a chally to build once the warrior and Scimitar is done!
So im using your build as a guide
marsiascout
KitMaker: 1,247 posts
Armorama: 913 posts
Posted: Sunday, April 12, 2009 - 10:13 PM UTC
I must admit that now you've changed the weathering a bit, it looks WAY better!
Lars
Lars
SIRNEIL
KitMaker: 658 posts
Armorama: 599 posts
Posted: Monday, April 13, 2009 - 05:26 AM UTC
pawel,jaymes & lars thank's for all the positive and constuctive comments
jaymes
i suppose the pressure is on me
Once the decals had dried i painted another coat of johnsons klear over the top of them but this time i used a brush.After leaving the chally overnight i mixed some mig oil paints wash brown & industrial earth with some white spirit in my trusty cat food tin.I then brushed the thinned oils using a 0/0 sable brush into all the nooks and cranys and around any bolt heads basically anywhere that grime would collect.Then i dried the whole model with an old hair dryer.This will really speed up the drying time of the pin wash, your talking minutes rather than an hour or so.
I sprayed two coats of vallejo model air flat varnish over the entire model.This was done so that i could dry brush the pigments onto the flat finish i find that this gives a really dusty effect.
The turret in this picture has been dry brushed with mig pigment dry mud P232 and the hull hasn't.
neil........
jaymes
neil........
newfish
Posted: Monday, April 13, 2009 - 05:36 AM UTC
Hi niel, Pressure whats that
Its coming on a realy treat nice work with the pigments!
Are you adding crew on this one?
SIRNEIL
KitMaker: 658 posts
Armorama: 599 posts
Posted: Monday, April 13, 2009 - 06:12 AM UTC
Yes jim it will have three crew men the two plastic ones from the kit with hornet heads and a left over one from blast models.
The picture below is a comparison on the left with the dry mud scrubbed in and left is without.
And below is after very small amounts of russian earth have been dry brushed.
neil............
neil............
newfish
Posted: Monday, April 13, 2009 - 06:25 AM UTC
Niel the mud you've put on has made a difference it looks superb!
jvazquez
KitMaker: 857 posts
Armorama: 811 posts
Posted: Monday, April 13, 2009 - 06:26 AM UTC
Neil, the fixed chipping looks much better and overall GREAT job!!
SIRNEIL
KitMaker: 658 posts
Armorama: 599 posts
Posted: Monday, April 13, 2009 - 11:17 PM UTC
jaymes & james cheers for your comments
Hopefully big jim has killed of the enemy known as DOS and we can all get back to normal.
On to the figures the two mini men up top are from the kit i have replaced the heads with hornet ones and the driver is a spare i had and is from blast models.......
I'm of to do the stadium tour of WHITE HART LANE official residence of tottenham hotspur football club..........
neil..
neil..
newfish
Posted: Tuesday, April 14, 2009 - 03:35 AM UTC
Hi Niel the figures look niceespecially with Hornet heads!,
btw going back to the size of the paint chipping the first ime you did them wern't over scale in a book ive got of my brothers batallion in Iraq theres some challengers and the desert paint has almost completely worn off and has allot of green showing through!
SIRNEIL
KitMaker: 658 posts
Armorama: 599 posts
Posted: Tuesday, April 14, 2009 - 06:46 AM UTC
DeskJockey
KitMaker: 1,558 posts
Armorama: 1,159 posts
Posted: Thursday, April 16, 2009 - 02:21 PM UTC
Neil--what Hornet head set are those from? They really are quite an improvement over the Tamiya heads, I have to say. I'll probably grab a set.
newfish
Posted: Thursday, April 16, 2009 - 02:53 PM UTC
, modern UK tank crew heads, 2 jigs
SIRNEIL
KitMaker: 658 posts
Armorama: 599 posts
Posted: Friday, April 17, 2009 - 01:28 AM UTC
Hi jim
Yes i think that your wright about the paint chipping,i could have gone a lot worse on the amount of green showing...............oh well maybe next time.......
They certainly are lucas, a nice little extra that comes with them are microphones cast from resin and a small jig so that you can bend some copper wire to attach the mic to the headphone.
neil............
They really are quite an improvement over the Tamiya heads.
neil............
SIRNEIL
KitMaker: 658 posts
Armorama: 599 posts
Posted: Sunday, April 19, 2009 - 08:48 AM UTC
Finally i have reached the finish line.I have not had much modelling time lately what with easter and my eight year old sons birthday but today i got to finish the figures.The trouble with plastic figures is that they are actually harder to paint than resin ones plus the fact that i have just found out that the british armys desert camo is i think very difficult to paint.The hornet heads were a dream to paint.I may not be that good at painting faces but it is one of the parts of building an AFV that i really enjoy and if they come out half decent it can really bring a 1/35 scale model to life.
Thank's to all that asked a question or just looked in at this build log.
I'm of for a pig's ear
neil............
neil............
newfish
Posted: Sunday, April 19, 2009 - 10:38 AM UTC
Hi Niel great work! it came out great!
whats next for you then?
DeskJockey
Posted: Sunday, April 19, 2009 - 01:34 PM UTC
Looks great, Neil! The chipped paint and weathering came out quite realistic.
SIRNEIL
KitMaker: 658 posts
Armorama: 599 posts
Posted: Monday, April 20, 2009 - 06:34 AM UTC
Hi jaymes
For some reason i have four dragon abrams in the stash so i think it'll have to be an m1sep.
Cheers lucas
neil...........
newfish
Posted: Monday, April 20, 2009 - 06:39 AM UTC
four?
lol
im not even going to ask ! but looking foward to seeing one of them
Straniero
KitMaker: 130 posts
Armorama: 127 posts
Posted: Monday, April 20, 2009 - 08:11 AM UTC
Merge two into a limousine!
Great work, love the weathering!
