Dioramas
"Loss of Innocence,Will It Ever Be The Same?"
dolly15
KitMaker: 8,227 posts
Armorama: 1,975 posts
Posted: Monday, July 27, 2009 - 04:00 AM UTC
dolly15
Posted: Monday, July 27, 2009 - 04:18 AM UTC
I love this pic!( I know only a modeler could get excited about bricks) Anyway,it gives you a great palette of brick colors to work with and the wall itself is so very interesting.
I can see an artist getting lost forever in this detail , being able to practice every technique in the book.It will surely be a case of knowing when to stop.By comparison modern brick walls are so very boring.
I don't yet have any idea of how to achieve that rough cement grout work look but I am working on it.I think my challenge will be to restrain myself and not to make my wall too old looking.
I love the way Andi builds a history into his brick walls but I wonder if that would be appropriate here.The row houses in my reference picture look fairly new in 1913 and the residents fairly well off ,judging by the way the lady with the dog is dressed and the fact that our early EAA type could even afford all the materials to build his airplane.
I can hardly wait to start the painting of this piece .It is as close to 2D picture painting that a 3D guy can get....
dolly15
Posted: Tuesday, July 28, 2009 - 03:03 AM UTC
dolly15
Posted: Wednesday, July 29, 2009 - 03:33 AM UTC
dolly15
Posted: Wednesday, July 29, 2009 - 03:48 AM UTC
Working out the color scheme.
The window frame will be my favorite dark green color.(see my photobucket for an example)I have put on a light green base coat over the raw wood and over that the darker green.When I get to the weathering I will lightly sand the surface to get a wear and tear effect,two tone green and in places raw wood, which then could be washed a light gray.
I am looking for a neutral shade for the bricks and light beige,the first half brick from the top in the pic,seems to look good.There has been one watery coat applied at this stage.The full brick above has two watery coats.I like to start with the light shades and work to randomly darker them when using washes.The edges of the brick have been painted now so that any overlap of colors will be the green trim and not the brick.
This watercolor paper is great to work with as it does not swell when water is applied thus preserving the texture of the brick.
dolly15
Posted: Wednesday, July 29, 2009 - 04:11 AM UTC
It has occurred to me that maybe I am going down the wrong path here.I am basically trying to represent what was a fairly new building in 1913.I look around my neighborhood at the brick structures after 20-30 or even 50 years and the bricks still look almost new.Maybe it would be a mistake to radically age my brick wall or try to build too much history into it.I love Andi's wonderful work but it may not be appropriate as as an example for which was a fairly new structure in 1913.
When to stop? What to leave in and what to leave out?
dolly15
Posted: Thursday, July 30, 2009 - 04:25 AM UTC
dolly15
Posted: Thursday, July 30, 2009 - 04:42 AM UTC
Man I wish I had a camera lens that didn't create so much distortion.Anyway,here is where I am so far.The upper right bricks above the sill are as dark as I plan to go.The lower right is a little lighter and to the left of that lighter still.I have used JoSonja acrylic gouache paint.It is their Gold Oxide straight out of the tube, mixed only with plain tap water to a consistency of 5% milk.You could thin it out to about 2% but that is not necessary here as my base color is quite dark.The key here is to not get too dark too quickly,it is better to err on the side of leaving it too light and then darken individual bricks to the shade you prefer.(like the bricks you see on the left in the pic)You want contrast between individual bricks.I have always worked from light to dark to take advantage of the transparency factor afforded by gouache acrylics.It can be a little time consuming painting individual bricks darker but it saves trying to lighten them later.
When putting on your first coat be sure to paint the white brick edges that have not been already colored with a small round brush.Don't worry about getting it on the foam board as it has a surface that does not readily absorbed the paint, which is a real advantage here.(saves you having to grout the spaces between the brick) Any space that remains too white can be dealt with by applying a second watery coat.
The reason that I do the spaces now is if your do it later the edges may turn out too dark and spoil your work.
Pick a shade of color that you like as your base coat (which will end up being the lightest value on the wall)and randomly darken the rest until you are happy.Don't go too dark right away as acrylics will darken naturally as they dry,much like house paint.In fact I will let mine dry over night and do the finishing touches the following day.
If you plan to do dry brushing now would be the time to do so,I haven't yet decided myself. I may just weather them by flicking on some crud using my toothbrush technique and then use pastels to finish.So far I am happy with the result,I think that it looks like a 20-30 year old wall.
dolly15
Posted: Friday, July 31, 2009 - 01:27 AM UTC
dolly15
Posted: Friday, July 31, 2009 - 02:36 AM UTC
The grey stone blocks where given the 5% milk treatment using JoSonja gouache acrylic.I used their Nimbus Grey mixed with a touch of Raw Umber and water.I darkened down the seams using the same mix and a small round brush.Try not to get too much on the face of the stone.
I really like this textured watercolor paper when using thin coats ,as it almost eliminates the need for dry brushing.Remember however one heavy coat and your in trouble.Not all is lost however ,as you can still dry brush the texture back if need be ,using a lighter tint of the same color.This is an example of the great versatility of acrylics.
The grey stones still need a little pastel shading and some crud along the bottom.
I would suggest to those who don't want to go to all this effort to make a brick wall ,if you think it looks good enough for your purposes especially in the smaller scales,when I am finished you could make a copy of the wall and then use photobucket to play with the colors and adjust it to any scale you want.Have fun!
Note: if you want a great tutorial on making scratchbuilt cars or aircraft in brass see my modeling bud Ken Foran's thread over on SMC.He is the best!
http://www.scalemotorcars.com
Look under Large Scale Cars in the Forum.
dolly15
Posted: Sunday, August 02, 2009 - 09:39 AM UTC
dolly15
Posted: Monday, August 03, 2009 - 03:53 AM UTC
dolly15
Posted: Monday, August 03, 2009 - 04:44 AM UTC
This is the pic that I am using for reference.The color seems about right except for the odd brick that is lighter or darker in value.These bricks that are beyond the norm will be selected and modified later when I finish the whole composition.
To complete the diorama I have another complete mirror image facade to build plus a small portion of a third rowhouse.I will have to find a way to break up this huge wall of the same color brick.Maybe with a subtle color variation of the brick , window frames or decorations of some sort.I think a little more research is in order.Any ideas?
dolly15
Posted: Tuesday, August 04, 2009 - 03:46 AM UTC
dolly15
Posted: Thursday, August 06, 2009 - 04:53 AM UTC
Another pic
dolly15
Posted: Thursday, August 06, 2009 - 04:54 AM UTC
dolly15
Posted: Thursday, August 06, 2009 - 05:02 AM UTC
Running along the top of the window I have added two rows of bricks that are in high relief as well as being a darker color.I think that this will help to break up this massive brick wall.I may do the same to the upper story windows as well.
I have temporarily tacked on the bottom sill of the dining room window.The green trim will be weathered a bit later.
dolly15
Posted: Saturday, August 08, 2009 - 02:40 AM UTC
dolly15
Posted: Saturday, August 08, 2009 - 02:47 AM UTC
This design seemed to be quite popular during Victorian times ,with the center piece being of graystone .I am getting there slow but sure.
dolly15
Posted: Saturday, August 08, 2009 - 02:50 AM UTC
dolly15
Posted: Sunday, August 09, 2009 - 04:20 AM UTC
dolly15
Posted: Sunday, August 09, 2009 - 05:53 AM UTC
How easy is it to screw up? Let me count the ways.
I think our brick layer came back to work after a liquid lunch and somehow screwed up the brickwork.I only noticed the following after taking the pics.The two rows of dark colored bricks on the R/H side of the dining room window,are not level with the left.
The easiest fix would be to make the whole thing three rows instead of two.The other would be to lighten the dark bricks with acrylics but that could lead to problems.Maybe I will try something with pastels.
The window sills will be only temporarily installed for two reasons,I may in future want to lay the facade flat on its face and two they are too vulnerable to being broken off.
dolly15
Posted: Sunday, August 09, 2009 - 09:55 AM UTC
dolly15
Posted: Sunday, August 09, 2009 - 11:23 AM UTC
another pic
dolly15
Posted: Monday, August 10, 2009 - 03:44 AM UTC
This will make a great backdrop for taking pics.I am planning to do a series of "Public Enemies" vignettes using 1/18th scale cars.I am afraid that the museum won't be getting this diorama for awhile.
It has taken me a month to build half a wall and am only about 1/5th of the way along.I am hoping that now that the design part is mostly finished things will speed up a bit, however there now will be the boredom factor to contend with now that most of the creative bricklaying stuff is behind me.
Someone pointed out to me that the blocks/greystones at the foundation are not placed properly.I should have known better, that you never line the vertical seams up one on top of the other, as this only creates a weakness in the foundation.A quick fix would be to re-do the foundation blocks by gluing new block faces over the old ones, which would mean the blocks would not be quite flush with the brick wall.I think that some foundations may have been like this anyway.I will take a look around and see what is out there.I could try hiding it with vegetation etc..but the problem is I know its there.
