Hi dave,
Thanks for the tips. I'm going to decal it a vehicle of 2IG (Armd) so I will have to add a plate or somethign to the front. WIll check a few references.
The PE is very small lol, lol, I may use lead wire for the straps, I'll see. As I want to do the top up I was thinking of adding some tissue over it to give it more texture, I shall see how that comes out lol, lol.
Al
Italeri Willis MB 4 x 4 Jeep - 2IG (Armd)
Posted: Saturday, June 27, 2009 - 06:42 AM UTC
Posted: Sunday, June 28, 2009 - 10:15 PM UTC
Hi Guys,
A bit more work. Added the bonnet catches and fashioned 2 side lights from grenades! Did a little basic weathering underneath before I added the wheels. Still the exhause to fit and some more work required there.
The wheels have 3/4 raised ejection marks on the inside that will need removed. A sharp X-acto blade will take care of those.
This is a cracking little kit for the price. Yes, a lot of clean up and thinning down of parts but so fat it has been a fun build.
There is enough play in the front wheels to allow you to angle them slightly, not 100% correct but better than straight on, I think!!! lol, lol
Now the fun part begins, sorting out a driver and adding some stores and kit to the vehicle.
Al
Al
Posted: Monday, June 29, 2009 - 12:18 AM UTC
Hi Guys,
Well with the wheels on and setting it's time to think about some crew.
There are acouple of options for British/Commonwealth drivers.
The Ultracast figure
and 2 from Doug's Originals
Driver
Passenger
These were all designed with the Tamiya jeep in mind I believe so I shall build them up and see who fits best. Additionally I have some Bren Crews that I haven't used so I may make one up from parts.
Al
Driver
Passenger
Al
Posted: Monday, June 29, 2009 - 02:50 AM UTC
Hi Alan. Another excellent blog. The jeep is coming together nicely ... good that you weathered underneath ... this is forgotten too often. Both choices of crew look good ... but the Doug´s originals have the edge ... that they are actually doing something ... but I guess that would also depend on the scene you are making.
Posted: Monday, June 29, 2009 - 03:05 AM UTC
Hi Frank,
Thanks. I'm leaning towards the Ultracast chap as he is very 'Mick' like. The other two are bit too parade ground looking although as the legs are separate I might switch the upper body. The Officer is also lacking a tie. They would be much better with the BD tunic top open.
Thanks for dropping in and glad you're enjoying the build. The hard part ie the windows has yet to come. I never have much success with those!!
Al
Al
Tonyfr
KitMaker: 516 posts
Armorama: 391 posts
Posted: Monday, June 29, 2009 - 03:55 AM UTC
Hi Alan,
Great progress on the Jeep. I like the Ultracast best if he going to be the only figure. The figures from Doug's look like they are talking to someone.
Tony
Tony
Posted: Monday, June 29, 2009 - 05:24 AM UTC
Hi Tony,
Thanks, made a bit of a FUBAR, I should have fitted the dash earlier
. A bit of filling and repainting required. Fitted the seats so it's looking quite jeep like and started work on the tarp.
Figures are soaking and I may see what alternative top bodies I have for the other 2 although i like the Ultracast chap too.
Al
Al
jjumbo
KitMaker: 2,012 posts
Armorama: 1,949 posts
Posted: Monday, June 29, 2009 - 06:06 AM UTC
He Al,
Any one of the three would do the trick, all depends on the scene you're trying to display.
Looking forward to the finished build.
jjumbo
jjumbo
Posted: Monday, June 29, 2009 - 09:46 AM UTC
Hi John,
Yes, there is that!
I was going to use the Tamiya windowscreen I had left over from the RA jeep. The detail seems better.
On the tarp the front end needs straightened up a bit, the lip underneath was at a bit of an angle. Hopefuly all will fit when done.
Some updates in the morning.
Al
Yes, there is that!
Al
Posted: Monday, June 29, 2009 - 08:29 PM UTC
Hi Guys,
This is the stage I got to last night. I added some cross bars to the inside of the tarp. I had thought about cutting out the 'holes' for the supports but then changed my mind. The seats and tarp have been dabbed with some Mr Surface to try and give them a slightly more material look. I shall see how the Tamiya Windowscreen works out. Need to paint the instrument panel, add the driver and steering wheel and on the outside mount the spare wheel and jerrycan. I cut off the moulded on spare wheel mount and will use a spare tamiya one or the PE one. I had considered adding a radio but that might be a waste as it will be covered over. Might add the antenna mount though.
Edit: BTW be careful when thinning down the tarp rods, they have a small locating pin on lower fitting and I snapped one off when I was getting rid of the flash and leftover spur.
Al
Al
Posted: Tuesday, June 30, 2009 - 01:32 AM UTC
Some Hours Later!
Added the Tamiya windowscreen it's not a perfect fit, need some alteration but the detail is better. Added a couple of small fittings to the sreen and a racked No 4 rifle.
Played around with some stores and working on the driver. On the tarp painted in the bars and added the rear window. I was unsure what to use, the kit one is 'glass' obviously not appropriate so I used a bit of the plastic bad the kit came in!!
Been looking at who was driving what and M5559240 driven by Gdsm Butler might be a suitable candidate. At least 2 of the other Bn HQ Jeeps were signals, One for the Sigs Sgt and one for the 2 R Sigs attached to the Bn.
Al
Al
Tonyfr
KitMaker: 516 posts
Armorama: 391 posts
Posted: Tuesday, June 30, 2009 - 03:23 AM UTC
Hey Al,
Looking really nice. Did you build the tarp from scratch? I like the driver, good paint job. Like the extras as well. Very cool.
Tony
Tony
Posted: Tuesday, June 30, 2009 - 04:29 AM UTC
Hi Tony,
Thanks. No, the tarp is the kit one with a few bits added. It has quite a nice texture but I added a little Mr Surface to give it some more depth.
A bit more work on the figure, he has some arms now!!. Need to let him dry well and them add some unit insignia and shadows, plus finish off the helmet and face.
Reqrganised the stowage a little, so stuff to paint up there. Not sure about anything on the bonnet or front. Need to add a bridge plate but hopefully if I can get the rest of the stowage finished, then a day or two should see the top fitted and the elements on the rear.
This is how things stand now:
Al
Al
Tonyfr
KitMaker: 516 posts
Armorama: 391 posts
Posted: Tuesday, June 30, 2009 - 05:01 AM UTC
Al,
You are flipping machine.
You make great progess. Are the white pieces in the jeep and the barbed wire something that came with the kit as well?
Tony
Tony
Posted: Tuesday, June 30, 2009 - 06:54 AM UTC
Hi Tony,
Unfortunately not. They are various bits of stowage from the carriers/airborne jeep I was building. Can't exactly remember where I got the ammo boxes maybe Accurate Armour, or could be SB Scotia.
Al
Al
calvin_ng
KitMaker: 1,024 posts
Armorama: 753 posts
Posted: Tuesday, June 30, 2009 - 06:59 AM UTC
hi Alan i think people have said this before but ill say it again , YOU ARE TALENTED! everyything in that picture looks great, the fig, again i love your painting and the jeep looks good! i cant wait to see the weathering
Posted: Tuesday, June 30, 2009 - 11:20 AM UTC
Hi Calvin,
Thank you kind sir, much appreciated. This one has been fun, but we will have to see what the final product looks like. Tomorrow should finish the figure and hopefully fit the top!
Al
Al
Posted: Tuesday, June 30, 2009 - 08:15 PM UTC
Morning Guys,
A bit more progress! Added some decals, but unfortunately my M555... No didn't work out so I've gone generic with a spare one form the AA set. Added the antenna mount and a B type antenna form my free item that I got form Resicast on my last order. Also the jerrycan holder, a spare from the RA jeep build and the Tamiya Spare wheel also left over from the RA jeep build.
Painted the stores and almost finished the driver although I need to wait for the decal fix to work on the shoulder insignia, dust his boots and add the steering wheel, plus try and dry brush the netting on his tin pot.
I'm not sure about adding some stowage to the bonnet, what do you thnk? Also here'a a look at the vehicle with the tarp on, only set in place so excuse the 'gap' which won't be a problem once I add some glue (I hope ).
Also with 2IG (Armd) being armour I though about adding the holstered .45 Thompson MG once the tarp is fixed?
The tools will be the last item as you need somewhere to hold this little fellow and there are some small grad handles that need to be added too.
Al
Al
Posted: Wednesday, July 01, 2009 - 02:17 AM UTC
Hi Guys,
Drivers in and the tarp fitted. I've strapped it down until the glue dries as the fit wasn't great. Main problem is the rear of the tarp catching on the rear seat, also had to cut and adjust one of the supports that got moved out of line as a result. Not perfect and might need a little filler on the back when I take the tape off.
Driver worked out well though, especially as there isn't that much room , the steering wheel went in fine.
I suppose it could be an ambulance jeep with a bandage on lol lol.
AL
AL
Tonyfr
KitMaker: 516 posts
Armorama: 391 posts
Posted: Wednesday, July 01, 2009 - 03:31 AM UTC
Al,
That looks great! Congrats on fine job. Now what are you going to do with it?
Tony
Tony
Posted: Wednesday, July 01, 2009 - 06:39 AM UTC
Hi Tony.
The fix is in, a little milliput, just want to let it harden overnight. and will post a few finished build pics for comment probably on Friday.
When I get to it I will join my IG tank troop dio I started building for 3 years ago so don't expect anything too soon lol, lol as it still requires a Humber Scout Car and that has been in the box since the kit came out.
Al
Al
Posted: Wednesday, July 01, 2009 - 08:23 PM UTC
Hi Guys,
This one is about done I think, thanks for the comment and input all those who joined in.
Al
Al
Tonyfr
KitMaker: 516 posts
Armorama: 391 posts
Posted: Thursday, July 02, 2009 - 06:33 AM UTC
Al,
Again great job! I really like the look of the roof. Look forward to your next build.
Tony
Tony
Posted: Thursday, July 02, 2009 - 07:33 AM UTC
Hi Tony,
Thanks, a bit of human interaction and interest always make the blogs much more fun.
Al
Al
jjumbo
Posted: Thursday, July 09, 2009 - 10:30 AM UTC
Hey Al,
Nice job on the Jeep and Ultracast driver.
Just trying to catch up on what I missed over the past 6 weeks, obviously lots !!!
jjumbo
jjumbo
