Well i've been away for awhile but i'm finally back with some updates. A few things happened, firstly I went on holiday to Brazil which kept me busy, and also my airbrush broke! While cleaning my Premi Air G35 the nozzle snapped in the airbrush and the thread of the nut broke off inside. It was while I was re-attaching the nozzle and using the small spanner in the set to tighten the nozzle in place. This was a bummer as it left me without a brush for a day, however it was a good thing as it also prompted me to go and buy myself another better brush. In the end I got myself an Iwata High Performance C Plus Airbrush which is just fantastic. I'm loving the HP-C+ and have found it a really lovely airbrush to use.
The Premi Air isn't totally out of action though as I ordered myself some new nozzles which arrived today. A little TLC and the G35 will be up and running too, the question is whether or not I will want to use it anymore!
Heres some progress on the terrain build. More texture to the ground and some vegetation added pre-painting stage (fir tree, log, and ferns). Flock and algae etc I will most likely add after the base is painted.
The fir tree will be weathered and covered with snow.
I also cracked into painting the T-55 which I primed first with Tamiya Primer then Tamiya Dark Green. I also made sure to mask and protect the interior at this stage.
I also got some work done on the tankers, which are heavily WIP at the moment:
Next stage on the T-55 was laying down a coat of Tamiya Flat White, built up in gradual layers, I then added a coat of Tamiya Clear mixed with Thinner to give a semi gloss and help with the oils and later wash stages, and then adding the Camo scheme using Tamiya Field Grey.
