Here's my latest update:
I drilled out two links of Cromwell Models early style tracks and pinned them. These will be my spares on the rear sides.
I almost forgot the tow cable hooks located just under the side air intakes. These are not in the AFV Club Kit, but are present in the Cromwell Models conversion set. I can't believe I almost missed these. Please note that not all Dieppe Churchills had these hooks, so check your reference before adding/omitting them.
Got the muffler shroud on. I painted it separately, glued it on, the over sprayed with a lightened version of my base color then over sprayed it again with some Nato Black around the edges to help blend it into the engine deck. I then did a pin wash of raw umber oils.
I simulated the shot out front head light with tin foil then washed it with raw umber to tone the silvering back a bit. Please refer to the original photos at the start of this build for reference. I used 32 gauge wire to help pin it in place. I'll have to add some smoke pigment or paint it black so the wire isn't so stark.
Tow cable add to LHS. As per the picture the tow cable was only on the LHS. The RHS cable was used to tow HELEN ashore. I painted the cable in the base color then added a little dust pigment and some metallic pigment to help it look more like a steel cable then a painted string.
I wasn't happen with my water proofing from before so I added more washes to help give contrast between the highs and lows.
OH God! Resin tracks! I despise resin tracks with a passion, just because I've never had any good experience working with them. I was hoping and praying that AFV Club would have their Plastic Early style track sets out by now... yet I find myself still waiting... They've been announced for about a year now! Come on!!
Oh well... I'm using my second Dieppe Churchill kit to help form the tracks, but I'm finding that the resin is either warped or my gluing sucks! I'll have to make a date with some boiling water to help straighten them up at some point...
I've made a list of remaining things left to do... not too much left before I switch to my Dingo, then my diorama... stay tuned!! Thanks in advance for checking my build log out!!
