Completed M923A1 and M198
KitMaker: 17,694 posts
Armorama: 13,742 posts
Posted: Wednesday, December 16, 2009 - 11:48 PM UTC
Man, you guys are right. How did I forget that too. Easy fix though. Thanks.
TANKER-NEIL
KitMaker: 13 posts
Armorama: 7 posts
Posted: Thursday, December 17, 2009 - 09:02 AM UTC
NICE WORK LIKE THE CAMO
michaelscott
KitMaker: 26 posts
Armorama: 25 posts
Posted: Thursday, December 17, 2009 - 07:40 PM UTC
Gino,
Outstanding job on both the Prime Mover and the Howitzer. I do have several questions that I hope you can answer. I noted that Vincent had mentioned that a portion of the barrel would not have any paint on it as a result of firing and you said that would be an easy fix. What would be the best method to use to paint that section to accurately depict the condition of the barrel? Would that portion of the barrel be a gun metal color? As you indicated, you are trying to evoke a sense of rapid redeployment to a new firing position, so the gun crew would not have had time to apply a protective coating of grease to that area. However if time were not a critical factor, how would you paint the area to represent the grease? I am unfamiliar with the color of WTR grease, and as there are many different colors of grease, what shade would most accurately represent it. Thanks for any insight you can provide. Once again let me congratulate you on a great build.
Scott
Scott
Posted: Friday, December 18, 2009 - 12:11 AM UTC
Thanks Neil and Scott.
I went ahead and fixed the barrel. I painted the area just behind where the step in the barrel is back to where it enters the cradle gun metal. Then I took a piece of t-shirt cloth and buffed it up a little when it was dry. Below are the results.
Scott, I didn't smear any grease on the area. The grease used is usually a light, muddy-brown color though. Its also commonly called GAA (Grease, Automotive and Artillery). Once it is applied though, it just makes the metal shiny. To represent it, I would give that section a coat of clear gloss.
Hope that helps.
Hope that helps.
GALILEO1
KitMaker: 1,794 posts
Armorama: 1,431 posts
Posted: Friday, December 18, 2009 - 04:13 AM UTC
Looks nicer we the correction. Learning quite a bit on this one.
Rob
Rob
Posted: Friday, December 18, 2009 - 07:11 AM UTC
Thanks Rob. Glad to be eductional as well.
skarik
KitMaker: 324 posts
Armorama: 295 posts
Posted: Sunday, December 27, 2009 - 08:30 AM UTC
Quoted TextHey Gino,
Why didn't you build an ammo truck. Ammo is not carried in the same truck as your soldiers.![]()
Hey guys...on the rounds, i thought I would provide a little insight since I was brought up on this gun in the 101st. Usually, the rounds and props ARE stored in the same truck with the troops, but they've now switched to 1098s instead of old 5-tons. For the rounds, we use a plastic "egg crate" which is strapped to a pallet at the rear passenger troop area and if memory serves it holds about 12 rounds. In front of that is the pile of prop cans strapped to the floor on the passenger side in front of the round egg crates. Sometimes ammo trucks are used, but usually for re-supply. The basic load of ammo is now stored inside the prime mover. Once the rounds make it to the prime mover, the crate is busted and they are loaded individually into the egg crate. Troops either sit on the driver's side troop seat or on top of the egg crate. There is usually a large wooden box built out of plywood with a lid that all firing equipment is stored in since you've got stuff like tube lights (for road transport), columator, etc, etc that can't be littered all over the floor of the truck.
If any of you need them, I have a few reference pictures of the inside of our prime mover combat loaded from my first deployment in 03.
Hello Vincent,
I would be very interested in the picture of the "in action" truck loaded. Would you please share it?
Regards
Jiri
Nightstrike
KitMaker: 114 posts
Armorama: 107 posts
Posted: Sunday, December 27, 2009 - 08:52 AM UTC
Nice build Gino. I can work with your hasty displacement theory. Enemy contact or manoeuvre to another firing point. Will there be a dio ?
Posted: Monday, December 28, 2009 - 01:47 AM UTC
Thanks Andy. No, no plan on a dio at this point. Maybe in the future though.
