Woohoo! Mother-in-law has finally gone home, so should be full steam ahead in the hobby room now.
I completed the last few steps of construction today
Step 23.
Attaching hull parts 3. This is adding lifting hooks to the engine deck. You have to be careful removing the smallest hooks from the sprue, I almost lost one to the dreaded carpet monster
As per other steps, I've left off the tow cable to paint separate.
Step 24. Photo etched grill. This is the final stage of assembly. The AA MG mount is assembled and attached to the engine access cover. Had a gumby moment this afternoon when going to paint the matt black into the engine grills. I brought a new bottle of thinners the other day, and after pouring some matt black into a mixing cup I added thinners. I gave it a stir, and noticed that instead of mixing, it was separating! I checked the bottle of thinners, and I had managed to pick up a bottle of enamel thinners instead of acrylic!
so after dropping the mother-in-law at the airport, we detoured to the LHS to buy some correct acrylic thinners. After spraying the matt black, and leaving it to dry for a few hours, I added the PE grills using CA. I'm sure I managed to clog some of the holes on the grills. I might use a pin to clear the holes, or maybe add minor battle damage.
Tomorrow I'm hoping to mask up few places on the Jagdtiger, and apply an initial coat of red oxide primer. It all depends on the weather, the forecast for tomorrow (NZ time) is Cloud increasing, evening rain. Humid northeasterlies. Low: 17°C (62.6°F) High: 25°C (77°F) even the next day isn't too flash either: Early rain then showers. Westerlies. Low: 17°C High: 24°C
Oh well, could be a good excuse to pull something else from the stash to start building
