Cleaning Your Airbrush
iakarch
KitMaker: 459 posts
Armorama: 421 posts
Posted: Wednesday, February 20, 2013 - 02:43 PM UTC
Using hot solvents can damage the packing and any o ring seals in the airbrush.
wrhouston
KitMaker: 20 posts
Armorama: 16 posts
Posted: Saturday, February 23, 2013 - 02:29 AM UTC
For all the time it takes, I've found it better to strip and clean my airbrushes after busing each clour.
TotemWolf
KitMaker: 294 posts
Armorama: 196 posts
Posted: Saturday, February 23, 2013 - 02:52 AM UTC
With my Badger 105 I can strip it, clean it and reassemble it in just over a minute.
Why not do so ever time I'm done for the day?
struman1
KitMaker: 10 posts
Armorama: 8 posts
Posted: Monday, August 19, 2013 - 01:44 PM UTC
I clean my every time. It takes 5 minutes and I never worry about spits and spatters
Posted: Wednesday, August 28, 2013 - 01:33 AM UTC
For what they worth, here's a how-to and videos I've made on the subject:
https://armorama.kitmaker.net//features/3131
http://youtube.com/watch?feature=c4-feed-u&v=UB7foX6mSS0
http://youtube.com/watch?feature=relmfu&v=QURv1Xg0OtI
GALILEO1
KitMaker: 1,794 posts
Armorama: 1,431 posts
Posted: Friday, March 07, 2014 - 11:32 AM UTC
Great thread!
Okay, so I need a consensus of sorts on using Windex to clean the airbrush. Should we be using it or shouldn't we?
I use Windex like most of you, I think, in that after shooting it I run lots of distilled water to make sure all the Windex is removed. Lately, however, I've been reading other airbrushing sites where just the mention of Windex as a cleaner gets people into a frenzy (even if you tell them that you use water immediately after to clean it out). They recommend never to use Windex or the such inside your airbrush.
So, are these people overacting or are they correct, for the most part? I'd like to keep my airbrushes going strong for as long as I could so being better informed as to what I put in them will help in this regard.
Thanks! Rob
Thanks! Rob
retiredyank
KitMaker: 11,610 posts
Armorama: 7,843 posts
Posted: Friday, March 07, 2014 - 12:33 PM UTC
I have found that I can run lacquer thinner through my brush, after alcohol based paints. I fill the cup about half full of lacquer thinner. After that, I run some glass cleaner then water. After each spray session, I break down the brush. I use cotton balls to clean the cup and q-tips for the rest of it. These I dampen with lacquer thinner. For the places I can't reach, I soak the brush in glass cleaner and ream with a brush. Occasionally, I soak the brush in lacquer thinner for five minutes. Such a short time does not hurt the brush. I reassemble it and run it under some lukewarm water. Looks and sprays like new, every time.
Posted: Friday, March 07, 2014 - 06:27 PM UTC
I have had very good luck when shooting Vallejo acrylics using windshield washer solution (alcohol and I suspect a detergent) followed by distilled water between colors. I usually only do a full disassembly at the end of the session or as needed. The analogy to firearms is a good one and disassembly and reassembly causes far more wear on parts than regular use.
sunburnthammer
KitMaker: 17 posts
Armorama: 6 posts
KitMaker: 17 posts
Armorama: 6 posts
Posted: Tuesday, June 24, 2014 - 10:03 PM UTC
Talking of cleaning airbrushes, I have stripped my first (iwata clone I suspect) airbrush and this bit dropped out. I can't work out where or how it's supposed to be fitted only that it provides tension. Anyhow, I bought another iwata clone because I couldn't repair my first and vowed never to let this bit drop out. Guess what happens today. The simplistic instructions don't really indicate how to put it back correctly. Any help would be welcomed.
Ian
Ian
SdAufKla
KitMaker: 2,238 posts
Armorama: 2,158 posts
Posted: Wednesday, June 25, 2014 - 01:07 AM UTC
Go to Google and search using the terms "Iwata Airbrush Exploded View Drawing"
Google Images::Iwata Airbrush Exploded View Drawing
In the first image that came up when I searched, your part appears to be #6, inserted into the AB with the small tab up, between the trigger #12 and a spring guide-operating rod #14. It appears to be a cam between the trigger and the needle tensioning system to control the paint flow.
HTH and Good luck,
HTH and Good luck,
alewar
KitMaker: 773 posts
Armorama: 765 posts
Posted: Wednesday, June 25, 2014 - 02:03 AM UTC
Hi, can I use the ultrasonic cleaner with my Aztek 470?.
I mean if its necessary due the type of disasembly of this kind of Airbrush?.
TIA
Regards, Alvaro
TIA
Regards, Alvaro
Posted: Wednesday, June 25, 2014 - 03:00 AM UTC
TIA
Regards, Alvaro
Not sure if it is 'Officially' Ok but I use a ultrasonic cleaner on my Aztek(s)
Posted: Wednesday, June 25, 2014 - 03:03 AM UTC
Hello Alvaro,
Yes you can.
I do a normal cleaning after every session and a through
cleaning, using a ultra sonic cleaner, once a month with
iso alcohol.
Joe
Yes you can.
iso alcohol.
Joe
alewar
KitMaker: 773 posts
Armorama: 765 posts
Posted: Wednesday, June 25, 2014 - 04:01 AM UTC
Thanks you Robbie and Joe.
I found here in my country, the same that you can found in Wallmart.
Regards from the south
Alvaro
Alvaro
M4A1Sherman
KitMaker: 4,403 posts
Armorama: 4,078 posts
Posted: Wednesday, June 25, 2014 - 04:58 AM UTC
Hello all! I have been modeling for 30 or so years and have been using an airbrush for about 20 of those years. After every use I totally take apart my trusty Badger 200 singe action airbrush and give it a total clean up. 75% of the time I use acrylics. I have been told by some modelers that Im nuts especially with acrylics, and that theres no need to do this EVERY time but rather every 5th or so time. Many opinions are to just shoot my cleaner of choice through and then clean H2o and be done with it, unless there is a clogging issue. What do you think or do? Thanks guys!
Hi, All!
Since I airbrush with enamels, (which I realize is somewhat archaic as acrylics have become the new standard in painting models) I use TESTORS Airbrush Enamel Thinners and TESTORS Airbrush Lacquer Thinners for my clean-ups. I use multiple airbrushes in each painting session, so that I don't have to wait very long between colors. I use 4 different airbrushes- 2 PAASCHE H1s, one of which is strictly for metalizers, a BADGER 200, and a BADGER 200G Gravity Feed model for touch-up work. These are all single-action airbrushes. I like to clean my airbrushes in a set sequence, using 2 small jelly jars of thinners/cleaners and one jar containing isopropyl alcohol:
1. Spray clean TESTORS thinners through the airbrush wide open for several seconds.
2. Break the airbrush down, then soak the individual parts for a while in TESTORS lacquer thinner. This is to loosen-up the paint residue, which I carefully help along by using pipe cleaners and cotton swabs to clean up the parts with.
3. Once this is done, the parts are immersed in the second jar of lacquer thinners for a short while- this is to catch any paint residue that I may have missed, just as an "insurance" step. As these parts are soaking, I'm usually spraying the next color with one of my other airbrushes.
4. I remove the parts from the 2nd soaking and place the parts on a clean rag to air-dry. I like to use old cotton t-shirts for this and for my brush-painting as well.
5. After the parts have air-dried, I soak them in my jar of isopropyl alcohol in order to remove any and all thinner residue. This is to prevent any thinner residue that may want to gum up the works.
It doesn't take long to do all of this- as a matter of fact, it takes longer for me to explain my process than to do the actual cleaning. A lot of you guys will no doubt comment that all of this extra work is un-necessary, but what counts is that it works for me, and I have never had any problems with my painting since I've started to use this process.
I use virtually the same cleaning process when I am brush-painting, with the added step of using regular hand-soap and water to rinse the bristles of the brush as a final step. I then wipe the brush gently on a clean paper towel, gently shaping the damp bristles of the brush to a point. This extra process helps to preserve the bristles, giving me extra brush-life. This also helps with the brushes that I use for dry-brushing...
sunburnthammer
KitMaker: 17 posts
Armorama: 6 posts
KitMaker: 17 posts
Armorama: 6 posts
Posted: Wednesday, June 25, 2014 - 08:10 AM UTC
Thank you mike roof, problem solved and airbrush fixed
SdAufKla
Posted: Wednesday, June 25, 2014 - 11:01 AM UTC
Cheers!
Happy modeling!
alewar
KitMaker: 773 posts
Armorama: 765 posts
Posted: Saturday, June 28, 2014 - 02:01 AM UTC
Hi again
Well, I buy one of this ultrasonic devices, the waltmart one.
I usually left the Aztek nozzles deep in "windex like" fluid.
I put the nozzle in the device, with only water, and after a while I can see some "spurs" from it. Not a lot, maybe the nozzle are enough clean.
So,I found the device too quiet, I don't see bubbles or so, just the nozzle moving a bit and the gum going out.
Its the device working fine? or I must expect more shake or bubbles?
Also, someone has tried with a dry paint?
TIA
Regards
Alvaro
TIA
Regards
Alvaro
sdk10159
KitMaker: 556 posts
Armorama: 433 posts
Posted: Saturday, June 28, 2014 - 02:30 AM UTC
Hi again
TIA
Regards
Alvaro
Mine runs for 3 minutes or so and is VERY quiet. I have to put my hand on it to feel the vibration, otherwise, there is no indication it's running. No bubbles. THe other indication that it's working is the paint gunk coming out.
Posted: Saturday, June 28, 2014 - 02:32 AM UTC
The device is working fine. You will not see bubbles or shaking.
The action of the ultra sonic cleaner is just vibration and
you may see slight rippling on the surface of the fluid.
This is all fine.
And yes it will remove dried paint maybe takes a little longer.
Joe
This is all fine.
Joe
alewar
KitMaker: 773 posts
Armorama: 765 posts
Posted: Saturday, June 28, 2014 - 02:33 PM UTC
Steve, Joe.
Thanks for the post. I glad to read that all runs fine. I figure that I need to saw more action inside!
Regards from the south!
Alvaro
Alvaro
SEDimmick
KitMaker: 1,745 posts
Armorama: 1,483 posts
Posted: Saturday, June 28, 2014 - 02:43 PM UTC
Be careful with ultrasonic cleaners, it took the plating off my H$S nozzles! They still work, but the chrome protection was taken off them.
RGasper85
KitMaker: 20 posts
Armorama: 20 posts
Posted: Friday, November 21, 2014 - 09:55 PM UTC
Do you guys have any advice for us who still use enamel paints? I have an iwata eclipse, siphon feed and a gravity feed with a .35 needle. Seems everybody is on to acrylics these days but my local hobby shop only has Tamiya acrylics and Model Master enamels
Tojo72
KitMaker: 4,691 posts
Armorama: 3,509 posts
Posted: Friday, November 21, 2014 - 10:10 PM UTC
I think I have the same gravity feed that you have and I clean mine with mineral spirits or enamel paint thinner
tenchu11
KitMaker: 37 posts
Armorama: 20 posts
Posted: Tuesday, March 31, 2015 - 03:08 PM UTC
I bought my dad one I those cleaners for his reloading to clean brass shells to a nice polish grit and gun powder free. I can just drain it clean it out do 50/50 water and model master thinner an it should clean the brush?
