Like most late war tanks (comet, Chaffee, JS2) and post WWII tanks (Patton, M60, Centurion, T55) the M26 has a very elaborate and complex fender / storage container design. Because of this the fenders themselves are going to be a very important focal point.
All of the fender components are scratch built and are constructed out of soldered sheet steel and brass. The parts are then mounted to the hull via steel fasteners.
The part of the fenders that was constructed first were the fender support / mount arms. The arms feature the correct "spot weld" seams that are present on the real vehicle. The arms were first attached to the hull with fasteners and glues. Epoxy was then added on top of the fasteners giving the arm more strength, and covering the fasteners with accurate weld seam detail. Small resin hex heads will be added to all of the corner extender points, but this will be after all of the sheet metal fabrication is completed.
The sheet metal fender panels where then cut, shaped and mounted to the suspending arms. The panels themselves have the side skirt mounting holes drilled into them. The tank's functional storage boxes will be fabricated and soldered directly onto these panels once they are complete.
The next fender parts that need to be created will be the front two fenders and the front and rear mud flaps. Once they are complete it will then be off to the fender storage boxes! More info to come
