I have added more new parts to the product line. Many of these parts will work on other vehicles besides M26 Pershings.
http://www.eastcoastarmory.com/ustankparts.htm
M3 90mm gun double baffle muzzle brake. This component will work on the M36 and M36B1 Jackson Tank destroyers.
M26 Pershing family Spent shell port hatch kit. This kit will also work on the M46 Patton family.
M26 family T80-E1 Live Track. The track is fully articulated and is very realistically detailed. The track is almost identical to the T80 track that is used on the M4 HVSS suspension. To transform this set for Sherman use I only need to make a different center guide tooth.
The tank's turret detailing is almost complete.
The turret spare track rack was fabricated out of sheet steel. A length of spare track will be mounted once the tank is finished.
The tank's engine removal studs were also added. These studs are only found on early production M26 Pershings.
The remaining turret details have been added. These would include the MP-48 spring antenna base, 50.cal travel lock, and the spent shell port hatch.
The only components that are left on the turret are the track tension jacks. Which will be done very shortly.
