Thanks to the CDs I got from our fellow armorama buddies...I spent a load of time with scrutiny and comparison of the photos to Trumpy's kit.
The areas that will take most of my time with be the cabling for the suspension details, M1200 conversion parts and anti-slip corrections.
I wish I had more time so I could attempt an Interior..Well I sure hope someone comes out with one before I glue the hulls!
A thanks to Brent Sauer and Seb Viale for their blogs which allowed me to note specific challenges in the parts.
To start...
There's 15 points to drill and modify in order to enable the front wheels to steer.
The biggest problem was finding the right location for attachment of the outermost bars to connect to the angled ones, with some trial and error I managed to Relocate it -- Approximately 1mm away from the original hole. You can see the tip of the rod sticking out through the thin plastic sheet I added.
I used various sized styrene rods to connect the parts, heated the end with a lighter and filed down..which acts as a stopper from the rod slipping out.
Rear suspension
Next update will include Voyager's and ETmodel's photoetch parts installed as well as my scratch build progress on the M1200 version.
Note the new cut out for my M1200 Cupola..
Can someone please advise how I can replicate the ceramic armor anti-slip ??? It's not totally accurate on Trumpy's kit and It's different on the M1200
I can only think of using cast-a-coat method.. Or Archer's wood texture surface decal..?
Various sized black wire from 0.35 to 0.5mm, there's also 1mm tubing and simulated corrugated duct as well as resin hose joints... Spending time to research what's available is surely a time and effort (and hair lost) saver when there's so many kits to build and detail! Using black wires would mean painting the kit first and then installing them.
I'll be using these wires for all my Rhino cables and for the replacement of my Buffalo MPCV's parts ---(much more on that much later on that WIP) The great thing is that the wires will tolerate quite some bending, chipping the black coating can still happen, but not easily!
If you want to know which wires..ask me!
