I'm finally back and want to apologize for the delay. I haven't lost base on this project but taking the advice given to me by Carmen Manning I decided to take a break from all the T Series Russian/Soviet vehicles for a week or so. In this time I began a Leopard 2A6M and an ASLAV 25 Phase III with bar armor.
However TODAY (more like tonight), I was able to put some work in. I had a side of tracks built already but the hardest part mentally was the painting of the road wheels. I didnt want to cut masks so I decided to spray Tamiya NATO green everywhere and hand paint the rubber. I used Valejo's Black Grey thinned with distilled water and this only took about 15 minutes, much less than what I thought it would take. I fitted the tracks and am debating how I want to display them.
So here is how I was able to get the affects on the fuel drum:
I began with the plastic and textured it by stippling on putty and liquid cement to bring sharp texture as well as a look at made the surface appear as if it was part of the barrel.
Next I applied primer and then this fancy stuff:
http://www.dickblick.com/products/instant-iron-and-instant-rust Its is an acrylic paint with real iron as a functioning pigment. So when you apply the rust solution it actually rusts.
I applied it a few times to make sure it was in a healthy amount and let it dry over night. Then I sprayed the Tamiya NATO Green all over, completely covering the iron.
Now with the rusting solution apply and wait. It will penetrate and rust the iron and after a few coats will show through as if it were the real thing. The more you apply the more of a rust appearance you will see. Its very easy to control. Lastly, I applied pigments and oils to blend the effects together as well as tone done portions I thought were too loud.
So thats all for tonight. I will weather the wheels tomorrow, assemble the other track and hopefully get a basecoat on those, although these Masterclub tracks really piss me off at times
Thanks for looking. The vehicle is starting to come together and I suppose I'm doing things right as each build is over taking my last by becoming the best build I have ever done.
Feel free to voice any criticisms and comments!
Until tomorrow
