Hi
I always think the issue of wood grain and its depiction on vehicles is questionable, so I wouldn't deduct points from my personal estimation of a kit for its lack of depiction.
Most times pretty hard to see on new vehicles covered in a good coat of paint in the real world, reduce that to 1:35 scale and you are unlikely to be able to see it at all.
I'd rather it be left off as it looks a bit toy like in most examples I've seen, and leave it up to the modeller if he wants to add it. The coarse sandpaper method as shown here for example I think is an ideal technique if you wish to depict woodgrain, all be it overscale![]()
Alan
I bought a wire brush type tool ages ago from MicroMark that was for creating woodgrain in styrene and other soft materials. The bristles extend and retract from the handle which has the effect of of adding or reducing depth in the pattern. I believe its intended use was in model railroading for buildings and the cars that had wooden components. I've used it with 1/48th scale aircraft components, 1/24 -1/25th scale automotive stuff, and some 1/35 military. It looks good if used with a light touch.
On the tire patterns, couldn't that be attributed to a civillian type tire and a military version? And then add to that a "use what is available" mindset to get replacements sent to the field?
