Quick work Sal well done !!!
Did you have the dio base done already ?
A quick tip on eyes for 1/35 figures.
Never paint the whites of the eyes white, if you paint the 'whites' at all and often you wouldnt see it in that scale then you should use a pale skin colour.
Sometimes a simple dark wash will do as far as eyes go ....
1/35 scale is the same as looking at someone 20 foot away, so try this and see how much white you can see. Look in the mirror from 6 footaway, and you'll notice the 'whites' are not white - they are a pale skin colour.
If you do paint eyes, add a very thin strip of this (light flesh) color to the eye, let it dry then add the iris with something like a toothpick splinter (don't add the iris in the middle, offset both slightly to the right of left).
Finally, the eye should also NEVER be round it should be a 'slit', so remove any roundness you end up with with the normal flesh color (by redoing the upper and lower eyelid).
Keep up the great work
I've started my 'Mirage / Toga Ltd" 7TP and I'm using the Frontline Illustration reference book (Crickey - it's in Russian !!), as well as Vol I and II of Tank Powers' '7TP'. All excellent references, with lots of plans, line drawings, and color profiles.
I also have "Vickers E, 7TP, C6P, C7P (Polish Tracks & Wheels)" by Adam Jonca on the way from Amazon :
Vickers E, 7TP, C6P, C7P (Polish Tracks & Wheels) I'm really looking forward to this build !!
I'll be using the Armo Barrel, Fruil tracks and the ABER PE (Although I may give the Full length PE Fenders a miss
A couple of figs are also included in the Togo Ltd kit (these originally were Hornet, Polish Tanker and Commander Sept '39).
Cheers and Seasons Greetings team !
