Continuing the triple build , few more steps:
I just build the Dragonīs 6183 suspension ...
Many boring parts...
The "rubber bands" on the bogie wheels are separate.
My initial idea was to paint and mount separately, which would greatly facilitate my task ...
But the rubber bands of the internal wheels did not "enter" after the bogies assembled (I glued the bogies.)
So, I mounted the rubber bands in the inside wheels (red arrows) and let the outside for once painted (blue arrows):
The 6183 kit suspension assembled and aligned:
Following the tips from this excellent article by Pat McGrath
(click here!!!), removed the oval covers on the back of Dragon oval and filled the cavities of links supporters, with putty...
While the putty dry, I devote my attention to the Academy's Easy ...
The plastic used (dark green) is much softer than the other two ...
As always I started the assembling by the suspension, which is much easier to build than the Dragons:
Then I discovered a little tragedy:
In my kit was missing a small return roller, one of E6 six pieces ...
Grrrrr...
Even though I have dental hydrocolloid reversible, the famous K27 ... (For those unfamiliar, please, read this
article !!!)
I glued a piece of E6 as "master" at the bottom of a form of plastic, with a minimal amount of glue.
Hydrocolloid was melted in the microwave (30 sec.), pouring the jelly on the box:
Here is the Eighth Wonder of the World:
With the normalization of the temperature of the jelly, it hardens (gels):
Allowing the removal of part ... Notice that there are two small bubbles (red arrows), but they are external, will not cause problems ...
As I just cast one piece, I use self-curing dental acrylic:
Acrylic mixed and poured into mold:
And the new little piece next to the original .... My problem is over!!
Stand up!!!!:
and the other side, showing the return roller "reincarnated" in his position:
Three amigos:
And as I was working with the Academy, I built the upper hull and did a dry-run with the turret, only to settle the worms ...
Bom, Senhores...there this ( for now...)
Stay tuned because more is out there ... I just hope that I have no more surprises with missing pieces ...
Waiting for, Gents !!!!
