DML Pz III N w/ Winterketten Blog
KitMaker: 5,425 posts
Armorama: 4,659 posts
Posted: Saturday, September 18, 2010 - 06:28 AM UTC
Bill- absolutely superb workmanship (once again). I apologize if I missed it in the thread, but what color and brand did you apply to the tool box and tool handles?
thanks
DJ
Thanks DJ! I used Testors Model Master enamels. For the wood handles I used my own custom mix of various colors (it's complicated, I just started mixing one day until I had the color I want which is basically a medium tan color that I then stuck a "wood" label on the mixing jar top!) for the base color and then apply a thinned enamel Leather wash over that. Not sure I understand what you mean by tool box, do you mean the jack block? If so, it got the same treatment. HTH!
Alabama, United States
KitMaker: 12 posts
Armorama: 2 posts
Posted: Saturday, September 18, 2010 - 08:38 AM UTC
Outstanding! I have always enjoyed your builds! Thanks for the effort you put out to photograph them.
On the workbench: 2 x Henschel Jagdtigers
KitMaker: 979 posts
Armorama: 959 posts
Posted: Saturday, September 18, 2010 - 08:47 AM UTC
If it was my model i would not add alot more weathering, the camo is looking good as is.
Posted: Saturday, September 18, 2010 - 09:22 AM UTC
Thanks
Gary, appreciate the comments!
Steven, the steps remaining aren't going to dramatically alter where the model's at right now in terms of overall finish, just add a little more subltety to it and tie it all together. It's the lower hull that's going to get the most attention in the form of some pigment weathering.
Posted: Saturday, September 18, 2010 - 03:40 PM UTC
Made great progress since the last update and the first order of business was to get the decal markings on. I applied a sealing coat of Future acrylic floor polish by airbrush and let that dry for a couple of hours before applying the decals. Each decal was treated with Walther's Solvaset to insure it snugged down tight to the surface and didn't silver. Once the decals were set, a 2nd coat of Future was applied to seal them in and protect them from the next steps in the weathering process.
I let the 2nd Future coat cure overnight and this morning I applied a light filter/wash of thinned enamel Raw Umber using a round 00 sable brush. This reduced some of the starkness on the whitewash areas and also served to tie the overall finish and decals together.
This was followed by a pin wash of enamel Burnt Umber applied with a 10/0 pointed brush to bring out all the various detail areas, weld seams, etc. Excess wash was cleaned up/adjusted using the same brush and some clean thinner.
The entire vehicle was sprayed with Testors Lusterless Flat in the spray can to seal everything in and remove any remaining vestiges of gloss from the Future coats. I mixed up a dry powder combination of Mig Pigments Russian Earth and Dark Mud and then added tap water with a drop of dish washing soap mixed in to break the surface tension to create a wet slurry mixture. This mixture was applied with a sable brush over the lower hull, tracks, and running gear and then allowed to air dry.
Excess pigment was then removed using first a series of stiff bristled brushes and then followed-up with a combination of dry and wet Q-tip ends until I had the look I wanted.
I'll give it a once over again in the morning to make sure I didn't miss anything or make any adjustments before calling this one done.
KitMaker: 5,854 posts
Armorama: 4,817 posts
Posted: Saturday, September 18, 2010 - 07:21 PM UTC
Bill: Well done! I wish I could build this fast and get such good results. You're skills have obviously been honed very well. Would you mind shooting a picture of the Tiger I and Panzer III together for us?
KitMaker: 6,149 posts
Armorama: 4,573 posts
Posted: Sunday, September 19, 2010 - 12:29 AM UTC
thanks
DJ
Bill-- thanks, I'll experiment.
Great job
DJ
DJ Judge
COL (R), USA
"Tanker Boots do not a Tanker Make."
Posted: Sunday, September 19, 2010 - 07:16 AM UTC
KitMaker: 979 posts
Armorama: 959 posts
Posted: Sunday, September 19, 2010 - 08:00 AM UTC
Very impressive, I purchased this kit today because of your build. I should be able to get it complete when I have finished my Panzer 1a and the other 10 kits I have waiting
I only hope that my Panzer 3 turns out as impressive as yours
Steven
KitMaker: 817 posts
Armorama: 555 posts
Posted: Sunday, September 19, 2010 - 08:48 AM UTC
another Fantastic build Bill, thanks for sharing
Ant.
IMMORTALITY! take it it's yours - Achilles siege of Troy.
Posted: Sunday, September 19, 2010 - 08:59 AM UTC
And just for Jeremy, here's a shot of the "brothers" together.
Much thanks mate! What and outstanding pair to display
KitMaker: 192 posts
Armorama: 165 posts
Posted: Sunday, September 19, 2010 - 09:42 AM UTC
I think you definately got this one spot on and showed great decision making in knowing when enough was enough.
Look amazing! A total inspiration. Thanks for this log.
Posted: Sunday, September 19, 2010 - 11:00 AM UTC
Steven, thanks for the comments and glad to hear my effort inspired you to get the same kit. Look forward to seeing what you do with it when the time comes.
My pleasure
Ant and thanks for the kind words.
Jeremy you are most welcome. It was interesting to me to see them side-by-side as well especially given the fact that they represent a substantial gap of almost exactly 3 years in terms of technique evolution time for me. Winter whitewash schemes aren't ones that I tackle very often with this particular build being only the 4th one I've attempted in the 9 years I've been building armor.
VM always tough to know when you've done enough...it's usually when you start thinking "I should just do this one more thing..."
Thanks for following along!
Vendee, France
KitMaker: 1,437 posts
Armorama: 1,406 posts
Posted: Sunday, September 19, 2010 - 08:18 PM UTC
Lovely work Bill
I like also the "family picture". And... very remarkable build speed
. Finally I must say the upper hull is quite weathered and it looks goooood
spit
European Union
KitMaker: 831 posts
Armorama: 791 posts
Posted: Monday, September 20, 2010 - 06:45 AM UTC
Brilliant as always!
Thomas
Punctuation, grammar and orthography are completely fictitious.
Any accordance with current or former rules would be completely random and not intended.
Posted: Monday, September 20, 2010 - 10:47 AM UTC
Thanks
Pawel and
Thomas, appreciate the comments!
#186
KitMaker: 771 posts
Armorama: 750 posts
Posted: Monday, September 20, 2010 - 11:17 AM UTC
Bill, I have to echo what everyone else has said. This was an awesome build, and done very quickly to boot! I'll be referring back to this one when I build mine. Nice job!
Posted: Monday, September 20, 2010 - 03:17 PM UTC
Thanks Guy! This definitely is one of the faster builds for me of late...the fact that it was done OOB makes a big difference along, of course, with the fact that I had a four day weekend due to the Labor Day holiday. I typically only build on the weekends so that was the equivalent of 2 weeks worth of build time squeezed into 4 non-stop days.
Glad to hear this will help you when you get around to your kit, look forward to seeing it!
Kobenhavn, Denmark
KitMaker: 155 posts
Armorama: 145 posts
Posted: Tuesday, September 21, 2010 - 04:26 AM UTC
Hi Bill
A great build as always, your blogs are always very informative and the weathering is just perfect on this Pz III.
I just love the picture with the Tiger I and the PzIII
They match up quite nicely.
Keep up the good work
Ole
For World Class modeling the Danish Way, look at www.ipms.dk
Posted: Tuesday, September 21, 2010 - 08:21 AM UTC
Thanks Ole, appreciate the comments and vote of support.
KitMaker: 251 posts
Armorama: 232 posts
Posted: Tuesday, September 21, 2010 - 01:39 PM UTC
Bill,
doe the blue tack work better than sillypuddy?
Posted: Tuesday, September 21, 2010 - 01:55 PM UTC
Bill,
Don,
That's a good question, I've never tried using silly putty before so can't honestly say how it compares. Both are used to achieve the same masking goal so it would be interesting if a side-by-side were done. I've never had any issues with the blue tack approach so have just stayed with what works vs. trying the silly putty method.
Utah, United States
KitMaker: 3,389 posts
Armorama: 2,054 posts
Posted: Tuesday, September 21, 2010 - 04:52 PM UTC
I've used silly putty before. It tends to creep into the smallest cracks and openings, and will stick if left on too long. Blue tac is much better.
Bill, great looking build. I'm amazed at the speed. I'm only halfway through the build portion of mine.
Great nations do not fall because of external aggression; they first erode and decay inwardly, so that, like rotten fruit, they fall of themselves. The strength of a country is the sum total of the moral strength of the individuals in that country.
Ezr
bill_c
Campaigns AdministratorNew Jersey, United States
KitMaker: 10,553 posts
Armorama: 8,109 posts
Posted: Wednesday, September 22, 2010 - 05:01 AM UTC
Another master modeler triumph!
Posted: Wednesday, September 22, 2010 - 05:51 AM UTC
Thanks
Russ and
Bill, appreciate the comments.
