General information:
Since Sept 2006 French Leclerc battle tanks (T6 and T7) patrol and surveillance the "blue line" between Israel and Lebanon. Revelant experiences in the blakans and other theatres have shown that more "serious" power ist needed to fulfill critial UN missions. No doubt the Leclerc helps to do so in the Lebanon.
For more Information on UNIFIL visit http://en.wikipedia.org/wiki/Unifil
The Kit:
The 1/35 scale Kit from Tamiya is a very good basis for this project. I would not recommend to use the Heller-Kit. Already out of the box the Tamiya wil build into a handsome model. See also the Armorama review from Pawel: http://armorama.kitmaker.net/review/1015
Aftermarket Parts:
Since the Kit is already a few years on the market a lot of aftermarket parts can be used. I have these parts but maybe not all well be used on this model.
- Bronco Leclerc MBT workable Track Link Set
- 35 073 Voyager PE set (because of the aluminum barrel)
- 35 844 Eduard PE set (because Edward just goes with ;-)
- Blast Models BL35138K, Update Set for Leclerc Series 2 (resin parts)
- Blast Models BL35079F, French Tank Crew Summer MBT Leclerc
- Echelon Decals, UNIFIL Leclercs - Echelon Decals, UNIFIL Leclerc
Information and books:
AFV Modeller Magazine Issue 36 Model (The model I chose 642 UNIFIL has been documented in this issue with some original pictures.)
"Landing Zone Lebanon" by www.blue-steel.info
Website of Oliver Carneau with some great pictures: http://olivier.carneau.free.fr
Excellent building blog by Rodolphe Uguen-Laithier on Website Panzerdesign
http://panzerdesign.fr/montages/vehiclesbuilding.html
And do not forget the outstanding "Tweaklist" by Olivier Carneau & Rodolphe Uguen-Laithier. But if you have chosen a particular tank you need to be aware of some slight differences. So take note of your reference pictures.
We start with the rear:
The access hatches were replaces by brass wire and the four bracked rods were replaced by hollowed styrene rods. Don't worry about the adhesive edges from tamiya extra thin cement it will be not be seen after the basecoat ;-)
At the rear lights I have closed the hole from behind with evergreen sheet and cut the glasses to size. Later I can easily paint the glasses and put it into the mount.
Antislip Surface with Rough Coat (Games Workshop):
For modern armor modeller the antislip surface is always a challenge. For me the tamyas antislip surface looks quite undersized. So I used the Rough Coat Spray from Games Workshop to replicate a thicker structure. Before start spraying ther is a lot of work to mask the model to prevent overspray.
Then shake the bottle well before spraying and make sure you work in a well ventilated area. I sprayed from a distance of 30 cm. In varying distance you can easily influence the grain of the coat.
Of course - the overspray will sometimes creep unter the masking tape. To remove overspray of Roughcoat I used a brush moistened with Revell Airbrush Clean.
Here is a comparison shot of the Roughcoat surface and the Tamiya suface.
Then a few missing handles have been added and glued from the inner side before finishing the hull. I do so to prevent from unwanted blobs of cyanoacrylate. The little spare PE part works as a distance holder.
Hull assembly:
The top and the bottom of the hull will be glued together. To keep the parts together tightly I use a simple clamping tool made from rubber sleeves and plastic tubes you find as tip-protector for brushes.
Drivers Hatch:
Next the drivers hatch was detailed with some aftermarket parts (white = from blast set, gold = from voyager set, silver = from eduard set).
Hull Front:
The front plate was detailed with some rivets (I often use my punch and die set ;-), pe parts from Eduard and the frontlights from the blast update set.
Hull Rear:
Serveral missing bolts were added, also engine grills from eduard and voyager. Bolted metal plates were replicated by evergreen strips cut to size and also the 4 snorkel brackets were added.
The funny construction (third hand & brush) helps to push down a warped pe grill. For pe parts I use white glue instead of cyanoacrylate. If I use too much white glue or something went wrong I easily remove the white glue with a moistened brush from the model surface. In the past I had a lot of problems with the cyanoacrylate. The disatvantage of this method is the long curing time of white glue - therefore I use the funny construction.
Sorry for my messy workbench ;-)
My chosen real tank - the UNIFIL 642 - had some differences. First a covering box on the right side was not mounted so I had to replicate some connectors.
Second the fuel pipe connector (middle of the rear) is missing the two tubes on the original 642. Larger holes for the fuel lines have been drilled into the blast resin parts for the barrel mounts. For the cable/ fuel lines I used lead wire from plusmodel in different sizes.
Next time I hope to carry on with this turret.
Because of shortly received cancer diagnosis and ongoing chemotherapy side effects (e.g. sensory disturbances in the fingertips) it is hard for me to stay with my hobby. Let´s see if I will manage to remain somewhat modelling anyway.
Comments are appreciated.
Glad to see you next time.
Walter
