Anyway, here goes.
Here I nailed a thin board to a support beam on an incline in order to have the incline of the beach.
Another picture of the board structure along with some materials. I'm going to be using DAS modeling clay for this diorama. I'm still experimenting with ground materials. In the past, I've tried celluclay and Plaster with varying results. Plaster is nice but a bit brittle and messy, Celluclay I find really unpredictable about cracking. I've only tried this DAS stuff on smaller things, but it comes premixed into a clay and seems pretty stable- it does not crack! And can be smoothed with water. I also have some Cadmium Yellow gauche and white gauche.
After adding some screws to the board, I've started to apply the plaster, smoothing it with water.
I positioned the sign and the wrecked boat fragment. Note that the plaster is still pretty wet. I had to keep constantly wetting my hands so as not to stick to the plaster. Very messy overall and I'm very tense about getting plaster all over the painted models. I recommend careful preparation of your space if you're doing this!
Just a different angle of the diorama. Note the built up area.
A small pic of the stakes that are going to be holding the barbed wire. I wrap it around the stake and press gently with small pliers. Mind you, that little barbed wire really does hurt your fingers if you press it. Talk about realism!
Here I've started to press small rocks and pebbles into the groundwork. I've also begun to place the bushes that I made out of my hemp rode into the groundwork and under the signposts.
Another angle shot. Note that I've begun to bury some of the barbed wire and smoothed it over with water as to imitate being buried in sand. The idea is that the barbed wire that was supposed to keep the boys off the beach has long ago rusted and broken.
So there it is for now. More to follow. I have to wait til some of this is dried before I can continue. The most nerve wracking part is mostly over now. I can rest easy at least until the painting. I find diorama building the most satisfying part of our hobby but also the most stressful and time consuming. The ground work alone demands alot of thinking and engineering I find. I'm sure there are people who can do it easily but I still struggle to do even the most basic groundwork.
As always, thanks for reading and comments and questions are welcome as are constructive criticisms!
