Ok, so I promised some updates and pictures and so here we go. Firstly I need to give some serious props and generous thank yous to Richard, who sent (at his own expense and without ANY compensation) me pieces from the Verlinden M60 Update set including almost the entire photo etch fret, just so I could have the brackets. Well, after looking at the brackets, I decided that I was going to forge ahead with the OOB build and I cannibalized my other ESCI Blazer kit I picked up recently and started on the kit bustle rack. I will be using my scratch built brass one on THAT kit at a later date. I really cannot thank Richard enough for sending that, as there are some other items on that fret that are going to come in handy later. This is where I started the day today:
I have been waiting to progress on the turret until after the bustle rack issue was settled. Once I received the Verlinden parts in the post I decided that I should just continue with the OOB, as that really is what this is about for me, trying to complete a kit (no seriously completing a kit) with minimal add ons. I was really NOT looking forwatd to building another bustle rack from the kit as it really is a serious pain. The parts are small and VERY flimsy. In fact I actually broke on of the parts (the first rung) while cleaning it up. I thought "GREAT NOW THIS!" But, regrouped and just glued the two pieces together and it was no worse for wear.
Having learned my lessons last time I figured out that the best solution to the alignment issues was to take this in slow steps and to only glue bits at a time, rather than glue one whole part down. I built the bottom of the bustle rack and the first rung, carefully. I left in some of the sprue guides intact to give it more strength during assembly, knowing that I would remove these at the end of assembly. I started adding the brackets one at a time and only glued the first rung to the bracket and NOT the bottom. I did this with each successive bracket until all four were connected to the first rung. I then lined this up with the slots in the back of the turret. marked the alignment with a fine sharpie on the fist bottom piece closest to the turret back. Then all I needed to do was go back and line up the brackets along those guides and glue in place. Once that was done the other two rungs were added and glued. next came the mesh, cut sized and glued.
The the bustle was attached to the support on the right side of the turret, which had previously been glued in place. Rungs were connected to their holes and then the left side was lined up. Each was glued and then the brackets were glued in place.
This was a moment of great success and happiness for me. The rest of the turret could now be moved ahead. I began by laying out all of the pieces for one sides blazer kit. Sanded everything down and then with a piece of drafting tape began to place everything onto the turret to see what placement was going to look like. The very first piece of blazer (G13) dies NOT fit in place. What you have to do to make it fit, I do not know, and really do not care right now. The blazer configuration has changed many times and I have several references and even within the same time frame there are differences. We'll call it poetic license. . . .
So working from the BACK of the turret towards the front I began installing the left side blazer kit. Just prior to starting I realized that I should install the crew bustle rung along the left and right sides otherwise there might now be a place to put them after the blazer kits were installed.
This is the left side after installation.
This is the area where the forward most blazer piece is "supposed" to go. . .
The right side was done the same way and really once you do this for one side, you know what to expect.
I had previously positioned the smoke dischargers but moved them today and this is where they ended up:
So most of my issues with this build so far, have been with the instructions. To say that they are "vague" is a bit of an understatement. Most pieces are shown where they go, but others there is just an arrow pointing in the general direction of that side. This can be very frustrating at times, so anyone who is NOT a seasoned modeler and is attempting to build this kit, pre-fit EVERYTHING, twice even.
I am holding off adding the blazer frame and 50cal over the main gun until the mantlet has a first coast of paint. I am worried the if it is installed it would be next to impossible to paint.
I have however decided that the kit supplied commanders MG mount is just too sad to allow and to my pleasant surprise the photo etch fret from RIchard has the commanders MG mount still on the tree. Now I just need to find someone who can scan me a copy of the M48 M60 Update set instructions from Verlinden, and I am in business. SO I have some turret details to add, the mg's and a couple of other hull details that I have chosen to leave off till now so that things do not get damaged.After that it is painting time. Looking forward to having this kit done and painted in the coming weeks. I am already planning on some serious gear stowage for this beast. That is it for now, cheers.
