Ryan,
Is the Tamiya turret the right length? From Paul's four-turret comparison it appears to be about 6mm longer from rear to range-finders than the others, which goes some way to explain the flat sides - looks like Mr T stretched it. If that's the case you could start by chopping a 6mm band from in front of the oval turret plate...
Tom
Tom the turret with mantlet attached is about 3/16" longer than the drawing. I can easily sand back the nose of the turret to get that into shape. I'm thinking of leaviing the range finders in place and building out the "deck" a head of the hatches to close that wide gap (betwwen the hatch plate and the RF's) by about .163". The antenna pots are a little too close to the hatch plate at the rear, but I'm not going to attempt to correct.
The sides need to be re-worked to a tear drop shape just as the flat begins towards the near the rear.
I don't have the right clamps to hold this in my mill, so I'll just hand job the rear plate cut and add sheet styrene to the front as explained above. This should probably happen first.
Pics comng soon!
Ryan
