Thanks Adam,
First of all this is my first Building Diorama. I have made several AFVs, a Morser Carl diorama and 250/1 diorama. If you call them diorama.Why. Because there are lots of mistakes i have made. Everytime when i start a model i say i will not make same mistakes or mistakes while building. On this one i have two common mistakes. 1. The canal could be more higher maybe 1 cm more. 2. I am not satisfied with the walls. It would be better with plasters.
Rest mistakes are cosmetics.
Before i start, i decided to make a bridge diorama. ( I need to have experience at buildings, bridge, water ) anyway. What i want was a mediaval bridge, with watch tower, buildings... I search net and i found two bridges that i like. One was the bridge at Bayeux. I choose it. Because the one i need should has stairs.. Then i draw. After a while the area near bridge was blank. I think and draw nearly one week. At the end I place one of the buildings at Bayeux right near the bridge.... Now i feel that the drawing was full.
Then I found a place for diorama at home for which i will placed at the end.
Into the shelf. Which you can see diorama from only two sides. But when time goes on, the questions you ve asked me came to my mind. Why too much efford for a diorama that has only 2 views. Or if someone wants to look from other sides ???
To solve it i know that i must do the interiors.
Or not say maybe in future.
Volkans
Dioramas
1/35 Wilderness
vayhan
KitMaker: 51 posts
Armorama: 45 posts
Posted: Tuesday, March 29, 2011 - 12:26 AM UTC
roudeleiw
KitMaker: 2,406 posts
Armorama: 2,224 posts
Posted: Tuesday, March 29, 2011 - 02:15 AM UTC
I understood Calvados as a brand of drink sorry.
Yes. Calvados, Bayeux
Yes, the name Calvados is , besides being a french region, also an alcool, not a brand by itself.
You can see a few brands here
http://www.netguide.fr/Marques_De_Calvados/
One of many french sites showing old wall advertising. Just click on the regios and departements
http://www.publicitemurale.fr/
GregCloseCombat
KitMaker: 2,408 posts
Armorama: 2,394 posts
Posted: Tuesday, March 29, 2011 - 03:17 AM UTC
You've gained another follower - I'm really impressed with the foam work too. Especially while juggling a 2 year old.
vayhan
KitMaker: 51 posts
Armorama: 45 posts
Posted: Monday, April 04, 2011 - 08:29 AM UTC
Thanks a lot Greg.
Claude sorry for my ignorance. I will try to search more.
I try to fade a bit. And put the windows.
vayhan
KitMaker: 51 posts
Armorama: 45 posts
Posted: Monday, April 04, 2011 - 08:36 AM UTC
I chose to make the roof with wooden tiles. With a 0.1 mm balsa sheet. I draw the lines first and will do the same thing i did to foam. I am not satisfied but lets see when it is dried.
Next will be the eaves.
vayhan
KitMaker: 51 posts
Armorama: 45 posts
Posted: Monday, April 04, 2011 - 08:38 AM UTC
The base coat painting
Still far away to end.
17741907
KitMaker: 953 posts
Armorama: 705 posts
Posted: Monday, April 04, 2011 - 12:17 PM UTC
Looking good so far Volkan...Will be great....Just keep on working....and good luck...
callmehobbes
KitMaker: 751 posts
Armorama: 740 posts
Posted: Monday, April 04, 2011 - 08:32 PM UTC
Looking good. I'm going to have a go with insualtion board myself at some point - much cheaper and easier to get hold ofthan balsa foam and basically the same stuff (extruded polystyrene). Thanks for this!
vayhan
KitMaker: 51 posts
Armorama: 45 posts
Posted: Thursday, April 07, 2011 - 10:30 AM UTC
Thanks.
paint on walls and walls. Walls have different colors. I guess when i use gray or brown filter , colors will not be confusing. Thats my theory.
vayhan
KitMaker: 51 posts
Armorama: 45 posts
Posted: Friday, April 15, 2011 - 10:03 AM UTC
I filter walls with milky color oil. Next i will try to paint some contrast colors like blak or blak+brown. Only 10 on a side.
Any comments welcome.
roudeleiw
Posted: Saturday, April 16, 2011 - 12:53 AM UTC
Is this a door on the left side?
As this part is situated near the water, don't forget the moss and other humid weathering.
Claude
Claude
vayhan
KitMaker: 51 posts
Armorama: 45 posts
Posted: Saturday, April 16, 2011 - 07:16 AM UTC
Yes Claude. Its a door. What i have planned is i need to make old hinges and above it i will do a rusted corrugated sheet ( if i can )
For the bottom of the building and the walls i need advices. I know that i will ones touch to the colors on them. For some contrast colors, filtering and weathering. Also humid weathering. But for the moss i dont have any idea.
I am following your thread and i know that you are using different plants' roots. I dont know how to find them. Those are true ones i guess because I dont want to the ones thats used for trees on train modeling.
PS : There is a stair on wall right side of the canal. the scale is wrong. ıts a mistake i guess what do you think ?
roudeleiw
Posted: Saturday, April 16, 2011 - 07:47 AM UTC
You mean the ladder on the first picture? It looks ok for me.
Moss!? No problem at all.
For very fine moss you use straight pigments. i often use MIG's Alied green for that. Other greens will do also (it's nature, don't be so exact)
Either applied dry or mixed with Ispropanol and then applied. The look will be different.
For moss with more volume you simply mix the pigments with any very fine medium you have.
This can be very fine saw dust, i also have dust from cork work. It also can be dust from Balsa wood ( you get that by sanding it)
Apply a bit of white glue and sprinkle the moss-mix over it.
I use a lot of roots but not in the moss. Where do you need roots?
Claude
vayhan
KitMaker: 51 posts
Armorama: 45 posts
Posted: Saturday, April 16, 2011 - 09:31 AM UTC
For moss, any fine with glue is a perfect idea. I will try it asap.
i am thinking to put a ivy without leaves. Just to take the monoton of walls. I mean maybe a little change will make more rich. That could wait a little.
Thanks Claude
Thanks Claude
vayhan
KitMaker: 51 posts
Armorama: 45 posts
Posted: Tuesday, May 10, 2011 - 09:06 AM UTC
Have done some fine work inorder to have the moss efect. More or less...
VLADPANZER
KitMaker: 568 posts
Armorama: 549 posts
Posted: Tuesday, May 10, 2011 - 11:04 PM UTC
Nice progress Volkan, can’t wait to see some water in place!
vayhan
KitMaker: 51 posts
Armorama: 45 posts
Posted: Saturday, May 14, 2011 - 09:23 AM UTC
Thanks Vladimir.
Bridge walls and cobble stones are painted somehow, but still needs progress.
I have used some house and road elements from Miniart. Dont know where to place them. The street lamp at front of the house is a tram lamp, its maybe weird but its the best one i have. I need some comments and advices.
raffrecon
KitMaker: 266 posts
Armorama: 258 posts
Posted: Saturday, May 14, 2011 - 02:16 PM UTC
Volkan,
Very nice dio. Mig Productions makes some very nice street lights. Also, lookinto model railroad stuff. I think G gauge is around 1/32 scale. You may want to verify that though. as I'm not 100% sure. Sometimes I use alter model RR items in order to get them to 1/35 scale. Like I said, Mig has some nice light posts.
Dan
Dan
vayhan
KitMaker: 51 posts
Armorama: 45 posts
Posted: Tuesday, May 17, 2011 - 05:51 AM UTC
Thanks Dan.
Its ( dont know the name ) build from aliminium folio. Doubled. Still need weathering.
need to repaint the roof. Yellow oil accident. OILS ARE DANGEROUS. I MUST CARRY CAREFULLY.
HONEYCUT
KitMaker: 4,002 posts
Armorama: 2,947 posts
Posted: Tuesday, May 17, 2011 - 09:41 PM UTC
Hey Volkan
this is my first time viewing this, and I must say that is is well impressive...
The favourite part for me is the 'contained' scene section on the bridge and in front of the building wall.The lower level of the building and the distance down to the water adds a great backdrop.
One thing I would definitely change is the corrugated iron over the doorway. I would make it with smaller corrugations and have it running top top bottom (think like the rain; it has to run off the bottom end!) Have two pieces side by side with a lap and a half of corrugation tucked under the next sheet. Your rust looks great but remember that at the angle it is, there would be minimal rust, and mostly in the 'valleys' where the water would run constantly.
Some great elements here mate. Well done
Brad
Brad
vayhan
KitMaker: 51 posts
Armorama: 45 posts
Posted: Wednesday, May 18, 2011 - 05:38 AM UTC
Thanks Brad. I swear i did not think the way of the corrugated sheet. I should change its way. And will try to make the distance of each corrugate small.
I think i will do it when i start to rain pipes.
Thanks for your comments.
dioman13
KitMaker: 2,184 posts
Armorama: 1,468 posts
Posted: Wednesday, May 18, 2011 - 05:54 AM UTC
Hey Volkan. Nice dio you have going there. For moss with body to it I use tea. Just open a bag and crush it more, glue in place and paint. That will give you the depth for large areas. Small sapling roots are great for trees and root systems. If they don't fit the way I need them I add wire branchs to them. I usually add a stain to the root trees depending on the tree type. Best to zap the roots in a microwave to make sure you don't get unwanted bugs hatching in your house or on your dio latter. Spring is when I go root hunting by rivers and streams. The ground is very damp and pulling up the small saplings leaves most of the delicate small roots intact. Hope this helps you some.
vayhan
KitMaker: 51 posts
Armorama: 45 posts
Posted: Friday, May 27, 2011 - 08:59 AM UTC
Ivy and some plants have implemented to dio. The rusted roof remade. Road repainted.
Still long way to go.
vayhan
KitMaker: 51 posts
Armorama: 45 posts
Posted: Friday, May 27, 2011 - 09:02 AM UTC
Hey Volkan
Brad
Thanks Brad,
Corrugated iron was absolutely wrong and i have changed.
vayhan
KitMaker: 51 posts
Armorama: 45 posts
Posted: Friday, May 27, 2011 - 09:05 AM UTC
Thanks Bob. I have tried to use little bit of tea at moss. Great shape or small leaves. Now i have teas ready with three colors.
