Sean.............. Yep that T34 image is pretty unique
Remco........... No worries... there's a lot of 'Campaign Frenzy' about.
I was going to use a ICM Panther D to practice 'Knock-ing Out' but it's still on route from overseas...
so I dug out a T34/76 I've had for about 20 years! which I was going to use in the Tamiya Campaign.
I spent an enjoyable evening whittling and cutting into the kit, quite therapeutic I think.
I cut off the RHD side arch (remainder needs more work) and bent and cut up the engine lid/deck to look warped, plus the LHD side mudguard got a pummeling! but that's about it for a first attempt, I still need to hit her with some holes using the pin drills and some correct size rod = 88mm impacts....
The reason I cut off the arch was 1. I over did the damage? and 2. I wanted to try cutting a big section out before I attacked my Panther model in the 'What If' campaign.
Wondered in to the local Artist supplies and purchased oil pints and brushes etc... felt very bohemian, lol!! wheels are now done, no tracks (rubber band type... ek!) coat of black tomorrow then I'm going to use ScatchMods Techniques
and see how I go !?
haven't been to precious but still quite pleased.
What to you reckon... input is welcomed guys.
Regards Duncan.
