welcome back to another of my build logs. In true Adam style I will try and photo every single step, and explain what I am doing as best as I can.
This vehicle is well covered in other blogs and threads on this site, so this is my spin on it. I have absolutely no first hand experience with this vehicle, Have'nt even seen one, so will rely heavily on those who have for "accuracy " issues.
This build will be Out Of the Box (OOB) so to speak, With no significant corrections planned. The purpose of this build is one of discovery - see how well the kit goes together, what subassemblies need attention, how much work it takes etc. I plan on doing several of these vehicles so this one is a shak e n bake version. Accurised (if required) builds will occur once we start seeing aftermarket appear. Until then... lets begin
I will build on the kitchen table - keeping it real simple with my most basic of tools. most importantly - the tv remote!
Just a few comments on the kit:
first impressions are comparable to early Dragon kits - lots of pieces but lots of moulding lugs. the detail looks good but isnt that perfect 'crisp' I would expect from a modern kit. instructions look very reasonable and easy to follow. I want to be a huge fan of this kit so much, I want it to be a success, and think its brilliant its come from an Australian producer. But if there are any issues we must talk about them openly so that we can overcome them and produce a fleet of bushies!
the first step is to assemble the axles assemblies. check out all the bits to cut off - this is going to be one of those kits that you have to guess what is detail and what is spare moulding lug...
at this point havent used any glue yet - the fit is that good ! but wow alot of flash / moulding seam to clean up
make two sets..
I cut off and start cleaning up some of the other parts... lots of sanding..
start assembling the "hubs" and rotors. interesting sub assembly this. The A frames are held in place by tiny pins that I promptly lost 2 of. They are undersized for the a frames, too short and really an ordinary design. On the rear axle I will do what sam did and use styrene. I wouldnt reccomend even bothering with the pins again.
the universal joints on the tiny drive shaft is next. In all my years of modelling I have never encountered such a fiddly bit of assembly. In fact the whole axle is fiddly but this will separate the men from the boys..
(drilled out the main shafts)
the parts - this thing is very small - about 14mm long
2 completed shafts
what makes them so difficult it they require assembly onto the rotor hubs and this would just have glue everywhere - I am using tamiya extra thin, but when I do the rear set i will switch over to super glue - the dry time lets the assemblies get all sloppy.
alignment issues are apparent almost imeadiately.
I spent much time looking at instructions and test fitting as I didnt understand the assembly, and thought I screwed it up as I had a massive camber, but realised I weas locating the a arms in the wrong holes - twit !
In order to try fix the alignment, I got the steering linkages on ASAP - but this didnt work as they are made up of several parts so instead of adding stiffness and a fixed alignment, they also suffered from the floating slop..
I soldiered on anyways - I hope I can fix any camber and toe in issues later ...
I chose not to glue the wheel hubs on, but did glue on the second layer of hub (its like an onion and has at least 3 layers to it ! ) careful not to glue the floating wheel pin - this is a big issue here and I think could be part of the axle ride height problem
but things are starting to look more aligned
test fit of axle onto hull - looking for that alignment through center of hub to lower stowage bins.. if this stays like this, it could be ok - the center of the axle is exactly the point which a line from the bottom of the bins would dissect.
here is a front veiw showing the camber and the angle of the suspension arms.
As I used the tamiya extra thin cement - everything was still "wet" so was able to slightly manipulate things to get good alignment and ride height. however there is a limit as the camber becomes obviously deformed at a certain point.
So some comments so far
Huurah I started!!! but,
the kit looks like it was designed to be a copy of how the real things goes together, not designed to be an easy build model.. if you get what I mean? I reckon so many parts that you could model an exploded one and choose how each part might look after driving over an IED... The sub assemblies are very fiddly, the pins are dreadfull and the whole thing suffers from a sloppy feel that has my gut turning at thinking how I am going to correct the alignment later..
The detail however seems extraordinary, and can't complain about level of accuracy ( I cant comment on 'scale' accuracy of course) . With experience will learn better ways of doing this assembly (axles) but had to do the first one by the book. Also with experience will learn which assemblies are hidden and dont bother cleaning as will not be seen ( like the layered hub assembly).
Well thats all for tonight - am burning candle at both ends for this - model comp in 11 days and I want this puppy ready!
