Not really a ton of progress today. I upgraded my computer of about 7 years age. It was a gaming pc back then and held out until now. Needless to say I was surprised at the technology leaps from back then.
Of course I had to build a new one:
Oh yea, before I begin, Bob really seemed to take a liking to sdkfz 10/4's with a spent casing basket. Well here are 2 more (For Bob's eyes only
Ok so, I decided to rebuild the range and acoustic holder. Don't ask why. The old one was a little broken and I had trouble working it, so I decided to scratch a new one. Here is the main support arm:
You may ask how I achieved this? Today's post is about working with styrene where one would otherwise use copper / brass. Sometimes I like using styrene over brass for a few reasons:
1) Styrene weighs less
2) Styrene can have multiple glue joints near one another. With soldering, it may be difficult to solder one section without disrupting another.
For these reasons, I decided to scratch the support arm out of plastic. I started it in copper, but I had trouble focusing soldering only one section without disrupting the other (some joints were only a few mm away from one another).
So here is how I achieved that in styrene:
I preload the part and place it over a soldering iron. Depending on how sharp I want the bend to be, I can control how long of a section I heat up. The preload helps be to know when the plastic is soft:
Once the bend starts, pull away and hold to shape.
And the same picture again with all of the bends in play. If you did this out of copper, you would find this part far easier. However, I will show you later the benefit to this method.
Here is the straight section of the post and its collar.
I had to bore the collar out to slip over the long shaft shown above. It is better to drill a little from one side and then finish from the back. This helps to ensure a concentric circle from start to finish as opposed to powering through one side only. If your bit is off center towards the end, it will find the hole you previously drilled and help keep it centered.
Anyways, I glued the shaft onto the collar. I also drilled a hole thingy to help hold the curved piece from before.
Kind of stupid looking?
Ah, but look at what a nice, affirmative glue joint it will make:
And glued.
Now the master melt class extreme. I originally had these parts in brass. However, these were a pain to solder to the main support as we will see. I'll show you how I built the following:
Don't worry it isn't that hard.
Same thing, pre-stress the part.
After heat application and cooling.
Now grab the part with tweezers and place over the iron:
The part will start to soften:
While it is still soft, turn it upside down and let the weight of the legs sag.
Re-straighten after bending to get even looking parts:
And trim:
The part I made for the picture is a little weird. I tried to show "in-action" shots, which isn't conducive to even parts. Anyways, I made some away from the camera and here is how they turned out:
Now I connected the holders to the main base with some styrene stock in between.
As you could imagine, that part would be hard to assemble if it was made out of metal. You would have to sacrifice and superglue joints because the soldering of certain joints would affect others. That is what I found.
Now I am fitting the part up to the base.
The above assembly is a little messy. I will clean this up tomorrow when the glue is fully done drying. Below are shots with the range finder support fit in (I have a nice interference fit of the copper part and the gun base, so I don't think I will need glue upon final assembly).
I love how the range finder looks on the 5cm Flak. It almost looks like a super beefy sight. Even though it swings out, I like how it looks in-line with the barrel. Very weird looking with those rings too (I don't know if these are acoustic or mini radar rings).
Hope you liked today's installment. Again, I am trying to show a lot of techniques that I use. They may be silly, but I utilize them all of the time. Each update, I usually have a new technique I will demo, so don't worry about repeating on later updates. If I bend plastic rod with a soldering iron, I will simply note I did. Today was just an good day to show the method.
I'll get there. I have to add the seats and front shields and I am done with the 5cm flak. I will burn through most of the DML sdkfz 7/1. I think Private Pile from Full Metal Jacket could navigate an obstacle course faster than I can model. Oh well, hope you enjoy and thanks for all of the kind comments.
Mark out.
