Thanks for the comments.
@Pedro: I think the work with your self-constructed is much higher.
The work with pe´s is not so hard than it looks. And it´is the first time i use a pe set. Before that i only use the pe parts in the box.
@Antoine: It´snot so hard to use pe parts on a model in braille scale. And you must not use all the parts in the set. I use only the parts i like. :-)
Looking forward to see the kingtiger.
I drilled out the tubs a little bit more!?!?!
The pe part for this is very good.
On the backside i glue the wires.
Here on the model.
The same on the other side. I think it looks better than the plastic part from dragon. ;-)
Only a little step today.....
Cheers Daniel
