Gino - Thanks for checking my lay. Yep....the brake lines are a Royal PITA but worth it.
Rounds Complete!!
1/35 M115 8 inch Howitzer WIP
redleg12
KitMaker: 872 posts
Armorama: 831 posts
Posted: Sunday, February 12, 2012 - 03:03 PM UTC
redleg12
KitMaker: 872 posts
Armorama: 831 posts
Posted: Sunday, February 19, 2012 - 10:14 AM UTC
A quick update for this week, I was able to get some weathering done. First I used MIG Raineffects to create some streaks on the vertical surfaces and details. Then I used a mix of MIG VN Earth and Dried Mud, about 50/50 ratio to add the weathering. After the pigment dried I brushed off the excess and worked in the horizontal surfaces with a small soft makeup brush. This is the current look of the howitzer.
Close up of a trail
View from above the bogie
From behind the breech
That’s it for now, next up, it is time for all the little details. I will be adding Section chest, HE Projectiles, Powder Cans, Fuse Box, Aiming Post, Ramming Staff, Bore Brush, Pail, Lanyard, Projo Carrier, Telephone, and some other Misc. items.
As always all comments are welcome
Rounds Complete!!
Close up of a trail
Rounds Complete!!
Tojo72
KitMaker: 4,691 posts
Armorama: 3,509 posts
Posted: Sunday, February 19, 2012 - 10:25 AM UTC
really nice work usual Mike
redleg12
KitMaker: 872 posts
Armorama: 831 posts
Posted: Sunday, February 19, 2012 - 12:33 PM UTC
Tony - Thanks for the peek and for the comment
Rounds Complete!!
Rounds Complete!!
bill_c
KitMaker: 10,553 posts
Armorama: 8,109 posts
Posted: Monday, February 20, 2012 - 12:17 PM UTC
Lookin' good, Mike! Can't wait to see the rest of the stuff around the gun.
KitMaker: 17,694 posts
Armorama: 13,742 posts
Posted: Monday, February 20, 2012 - 01:36 PM UTC
Coming along great Mike. The weathering looks great. Can't wait to see t finished with the extras.
redleg12
KitMaker: 872 posts
Armorama: 831 posts
Posted: Tuesday, February 21, 2012 - 12:42 PM UTC
Bill - Thanks for the peek and for the comments.
Gino - Thanks....#3 laid and safe...next up the ammo section stops by and the section unloads their equipment!!
Rounds Complete!!
Rounds Complete!!
redleg12
KitMaker: 872 posts
Armorama: 831 posts
Posted: Sunday, February 26, 2012 - 01:45 PM UTC
Here is a quick update on detail work. First I worked on ammunition. The 8 inch projectiles and powder cans are from the AFV 155mm/8inch ammunition kit. The projectiles and powder cans were painted with Tamiya XF62 OD. Then after a coat of future, I masked off the rotating band and it is painted with Tamiya Flat Copper. The lifting bolt is dry brushed with Alclad Steel. Then I added the projectile decals. The powder can was treated the same with Tamiya OD, future and then top edges and chime dry brushed with Alclad Steel. Then the white band decal was added. Here is there current state, once the decals have a day or so to set I will dull coat and they will be ready for mounting.
Aiming posts were the primary reference used for aiming. Using .060 styrene coated wire, it is cut slightly longer than the 2.75 inch or 8 feet full scale. The fun part is cutting masking 3.75mm and creating the candy cane.
Then it is off to the paint booth and using Tamiya Flat Red.
After flat coat the aiming stakes will be weathered and one mounted in the line of sight of the panoramic telescope.
Cleaning the bore is a continuous issue with separate loading ammunition. This pail is from the Warriors artillery tools set. It is primed with Tamiya Flat Black and then painted with Alclad Steel. The handle is 20 gauge SS wire bent to fit. Inside the pail is a mix of clear urethane with some MIG Dark Wash to make an oily mix to simulate Bore Cleaning solution. This will be paired up with a ramming staff with a bore brush still to come.
Every howitzer section always has a tool chest. This would hold the fuse wrenches, and special tools used on the particular howitzer. This chest is a small resin company, which is painted with Tamiya OD. The hinges and latch are dry brushed with Alclad Steel and the box edges are dry brushed with Tamiya Buff to simulate wear down to the wood. The chest is weathered with MIG Industrial City Dirt pigment.
That’s it for now, more details to come.
Rounds Complete!!
Rounds Complete!!
redleg12
KitMaker: 872 posts
Armorama: 831 posts
Posted: Sunday, March 04, 2012 - 02:43 PM UTC
Well here is the finish. First some of more details, the bore brush, I used my punch set to punch .160 to punch felt I use for the pads under the base. Two punched pads glued together to make the brush. Some .020 styrene punched for the brush end caps. Then the .040 styrene coated wire for the ramming staff section, 1.375 inches long. The end caps and the ends of the ramming staff I painted with Alclad Steel. The main section of the staff I painted with Tamiya JDSF Green. Eventually it is weathered with same MIG pigments used on the howitzer.
Next, I made the ramming staff. Similar to above using .040 styrene rod 2.75 inches long (2 sections) and punched .020 styrene sheet for the .160 end plate to make the 8 foot ramming staff. Painted same as above.
The aiming post painted in my last update, I weathered with MIG Light Yellow wash and Alclad Steel to create the scratches
The projectile carrier I made using some leftover PE cut to size to match the projectiles. Using 20 gage SS wire I shaped the handles on either side and the two set of feet. Since they were already a steel color, no other finishing was required.
The most important items to a towed artillery crew is the shovel and pick. Out of the spares pile, the heads and shovel handle were painted with Tamiya Flat Black. The wood portions were painted with Valejo wood primer. The scratches on the metal parts I dry brushed Alclad Steel onto the ends and the wood scratches I dry brushed with Tamiya Buff. Finally the dirt was added using the MIG pigments used on the howitzer.
The bogie wrenches come with the kit. I painted the handles with Poly Scale OD and the ends with Alclad Steel. They were finally weathered with MIG Light Brown wash. I positioned one on each side of the bogie.
The tarp under the projectiles I made with airplane tissue. First the ends are cuffed and glued using landscape cement. After it cuff seams dried, the tarp was placed using landscape cement and once the cement dried it was painted using Tamiya Olive Green. The tarp was then weathered with the MIG pigment mix.
After adding the projectiles, a .50 cal ammunition can was added as a fuse can for the projectiles. The .50 cal can came from the spares box and was painted with Poly Scale Medium Green.
I added “oil” stains where the bore brush would be carried. Here you can see the oily stain on the howitzer trail and on the ground around the pail and under the breech. Lastly the brush and end of the staff was also coated to create the oily look all using Floquil Bright Oil.
Lastly, I added the all-important lanyard. The lanyard is from wax covered ship string, then painted with Tamiya Olive Green. The connector hook is 26 gauge SS wire threaded through a drilled hole on the trigger mechanism. The .30 cal ammo box is for primers, also from the spares box and painted with Poly Scale Medium Green.
So, with all the details complete, here is the completed big 8 inch howitzer!
Thanks for following along. On to the M4 HST with the M5 Carriage Limber up next
Rounds Complete!!
EOM
Rounds Complete!!
EOM
Posted: Sunday, March 04, 2012 - 03:27 PM UTC
Looks great Mike. Excellent job.
redleg12
KitMaker: 872 posts
Armorama: 831 posts
Posted: Sunday, March 04, 2012 - 11:39 PM UTC
Gino - Thanks for the peek and for the comments....always good to have my brother stop by!!
Rounds Complete!!
Rounds Complete!!
trahe
KitMaker: 1,158 posts
Armorama: 950 posts
Posted: Monday, March 05, 2012 - 01:18 AM UTC
Mike, outstanding work! Really like the extra details you have added. Regarding the rotating band you painted copper on the projos, I believe what AFV has molded there is not the rotating band, but the plastic/fiberglass cover used to protect the rotating band. I'm an old 105 guy, so I could be wrong. Again, outstanding work!
bill_c
Posted: Monday, March 05, 2012 - 05:02 AM UTC
Looking like a show stopper.
trickymissfit
KitMaker: 1,388 posts
Armorama: 1,357 posts
Posted: Monday, March 05, 2012 - 06:34 AM UTC
she looks good! Got a couple questions for all the folks in the know.
I notice that the powder canisters didn't have any decales for the powder lot numbers. Did AFV not include any? The rounds you built up look just like the ones I handled when I was young and felt like I could lift 500lb. Also the aiming stakes you built up are nice, and a nice touch. Does anybody make the lights that were often attacked to them for use at night?
gary
gary
redleg12
KitMaker: 872 posts
Armorama: 831 posts
Posted: Monday, March 05, 2012 - 01:11 PM UTC
Tom - Thanks for the peek and for the comments.
As for the rotating band, yes they appear to be with the covers. Only a Redleg would pick that up soooo I took a bit of artistic license. I started my time on the 175mm then 8inch but spent most of my time with the 105mm also.
Bill - Thanks for stopping in. Hope to see you at Mosquitocon!!
Gary - Ahhh yes the AFV kit comes with decals for the powder cans but they are more for our era....VN and would not be correct for Korea time period. The M1 Green bag charge for the 8 inch would have had white lettering with a white ordnance bomb on it.
As for the 500 lbs and in better times....you and me both...not quite 500, closer to 200 but still enough to cause a pair fall off if you tried it alone.
Lastly, the stupid aiming post light. So without further fanfare...you mean
Yes....every old Redleg should have one!!
It is 8.75 inches long or 0.25 in 1/35
1.75 inches in diameter or .050
The light cover is also 1.75 dia and projects 1.5 in or .040
Now you have given me an idea to add a cherry to the current build. I will have to play with some styrene rod and scratch me up a light.
Thanks old buddy...hope the picture brings back the memory....
Thanks again guys
Rounds Complete!!
Thanks again guys
Rounds Complete!!
bill_c
Posted: Wednesday, March 07, 2012 - 11:25 AM UTC
Mike, yes, I hope to be at MosquitoCon. Hope to see you there. Have lunch with Georg Eyermann and Neil Stokes and me.
redleg12
KitMaker: 872 posts
Armorama: 831 posts
Posted: Wednesday, March 07, 2012 - 02:03 PM UTC
Yep....I will probably have Matt Toms, Dave O'Meara and Bill Schmidt with me....the usual place for lunch!!
Rounds Complete!!
Rounds Complete!!
