What is cellulose thinner?
Grenade
KitMaker: 29 posts
Posted: Saturday, October 18, 2003 - 01:46 AM UTC
I'm wondering what cellulose thinner is? Is it acetone, xylene, anyone good at chemistry out there?
Posted: Sunday, October 19, 2003 - 01:35 AM UTC
:-) I don't know about the chemistry, but cellulose thinner is "hotter" than most types of thinner used for thinning model paints. I use it to soak my airbrush parts in, between use. Cellulose thinner will strip most paints. I do use it to thin Xtracolor paints, it dramatically speeds up the drying time. I believe cellulose thinner was used in car paints, before the newer, more environmentally friendly types came on to the market :-)
What are you thinking of using it for?
Mal
Mal
Posted: Sunday, October 19, 2003 - 02:09 AM UTC
Hi there
Cellulose thinners is known as laquer thinners in some countries, and seems to contain Methyl Isobutyl Ketone ... whatever that is. Basically, like Holdfast says, it's much hotter than most thinners, and you should allow plenty of ventillation (and wear a proper mask) when spraying it.
All the best
Rowan
All the best
Rowan
Grenade
KitMaker: 29 posts
Posted: Sunday, October 19, 2003 - 06:58 AM UTC
Holdfast: I was thinking of serving it up on the rocks, maybe with some soda
- naw - Actually Humbrol sez use cellulose thinner to clean up brushes used to apply maskol (liquid mask). This stuff turns into rubber pretty quick and its hell getting it off the brush without ruining it.. Any tips would be appreciated!
Rgrds - Grenade
Rgrds - Grenade
Posted: Sunday, October 19, 2003 - 05:58 PM UTC
Hi Grenade
I normally use artists' latex because it's a lot cheaper than Maskol, but I think it's basically the same stuff. Cellulose thinners does help clean clogged brushes, but it's better not to let things get that bad...
I use an old (or cheap) brush and wet it first with water. If the brush is damp, the latex doesn't seem to cling to the bristles so badly. I wash the brush in water very frequently and usually avoid too many problems. Clean the brush with celliuose at the end of the session.
Hope this helps
Rowan
Hope this helps
Rowan
GeneralFailure
KitMaker: 2,289 posts
Armorama: 1,231 posts
Posted: Sunday, October 19, 2003 - 09:55 PM UTC
chip250
KitMaker: 1,864 posts
Armorama: 727 posts
Posted: Monday, October 20, 2003 - 12:35 AM UTC
I hear that cellulose thinners will strip paint really fast, and then dry at a cery high rate. Is it hard on brushes, more so than normal paint thinner?
~Chip :-)
~Chip :-)
tek2
KitMaker: 156 posts
Posted: Monday, October 20, 2003 - 03:05 AM UTC
Hi All
I'll make this short. Cellulose thinner = Lacquer thinner. Applying lacquer thinner to model plastic is not a good idea. It will melt if not wiped off immediately!
varanusk
KitMaker: 1,288 posts
Armorama: 942 posts
Posted: Thursday, February 25, 2016 - 02:16 PM UTC
I think that after 13 years since he asked he has had time to find the answer
11Bravo_C2
KitMaker: 475 posts
Armorama: 394 posts
Posted: Sunday, February 28, 2016 - 12:29 PM UTC
I think that after 13 years since he asked he has had time to find the answer![]()
I was thinking the same,
