On the top side, the feed arm tracks and direction switch are correct in the bolt top, BUT..where's the cartridge stop? Both the Dragon gun and the K59 have not only the correct tracks and switch, but an accurate cartridge stop.
So....looking at the rest of the parts, here's the truth. The Tasca is pretty good. A+ on dimensions, sharp molding. A+ on including the open reciever bottom. I would say this is at least a good base reciever for a detailed model, but it's not all it was cracked up to be, and it's still not as good as the K59 resin M2, as it forgets the cartridge stops in the feed tray, has no hex shape for the breech lock cam nut, and really doesn't improve any other things which all the model makers leave out, like the big screw slot in the end of the buffer tube, the rear sight assembly (only K59 has a good one), the trigger set with the trigger and bolt hold open/single shot trigger, good molded spade grips, and little things like the top cover latch and back plate latch. To point out more positives, the Tasca parts are sharp, and the retracting handle, barrels, especially the barrel handles, are really good. It's actually above the Dragon model by a good bit, but really not as good as the K59. Nope. K59 still has it beat.
