Seems like ages since I last updated this blog, about 6 ago weeks I think. Thats not to say I haven't been busy, there has been major changes to this build. The biggest change to this model is that it is now an exterior model. I know this will disappoint some of you but I just couldn't bring myself to the interior all over again.
So, heres the photos of the model in its current state. I'll explain a few things between the photos
The zimmerit is hand made with milliput, about 1 and a half packs of the stuff! The kit comes with zimmerit tools which were rather handy. The main gun barrel on my build is a limited edition which was produced by Gunnar Jansson. He sold these via the AFV modeller forum dedicated to this kit. It is extremely well produced item with superb detail. I was luck to get my hands on it!
I decided to use the kit side skirts as they are decent enough and due to the cost of the build I decided it wasn't worth spending even more money.
The main tow cables are by Schumo which are very nice items. The track pulling cable is from the kit.
The tow cable mounts are also from Schumo and although not entirely accurate, they do look very good. I used the kit gun cleaning rods. The tool clamps are from voyager. I did try to use the aber parts but at 8 parts per clamp I just found them too over complicated.
Up at the front I replaced the mg34 with an aber item which is a huge improvement over the kit item. The front periscopes are AFV modeller resin items. The wiring for the headlight is lead wire
The engine mesh screens were replaced with aber items and bolts were added. I used the kit frames and mesh for the raised screens. Welds were added to all the lifting hooks.
Welds were added to all the periscope covers and vane sight. The aber sight was added to the forward periscope on the commanders copula. You can see that the connecting track links have plenty of knock out marks to fill!
A close up of the muzzle brake. I have the larger version.
The C hooks where replaced with items from schumo with aber clamps. The jack block was scratch built. The clamp and mountings are from aber. The u hooks are from schumo
Close up shots of the schumo tow cables and their clamps
Theres still a few bits left to do such as add the fire exstinguisher and ariel. The inner guide horns on the tracks need to be sanded down slightly as the tracks do not sit properly around the drive sprocket. This is true of the tracks on the real thing but its hard to spot.
Matt
