This has been a long week getting my daughter back to college so the little bits of progress I kept to the doors
After coating the doors with airplane tissue, the doors were painted on one side with Vallejo OD Green. After the paint was given overnight to dry, I then using a new sharp #11 blade cut out the window areas and removed the tissue.
After the windows were cleared the other side of the doors was painted. I also painted one side of the window frames. On the unpainted side I applied contact cement. In my particular case, 3M photo mounting cement. This was done by spraying a small amount of the cement into a disposable cup and then applying the cement to the frame with a small detail cotton swab.
Once a set of frames was ready with I cut, with a new sharp #11 blade, a strip of clear stretch wrap plastic. Then I applied the stretch wrap to the frames starting on one side and working to the other while keeping the stretch wrap taught and straight. After pressing to the frames, again using the sharp #11 blade I cut around each frame and removed it from the PE sheet. Here is one of the small windows when removed.
Again, using the contact cement, I place a small bead on the tissue side of the window opening on the door and then applied the frame with the clear window to the door. Here is a view of the small doors with the windows applied.
Once all the windows are applied it is time to remove the doors from the PE Sheet. Here is how the sheet looks with everything installed
Once again using a sharp #11 blade I removed all the doors and the hinges. Since I intend to display with the crew compartment open, I folded the hinges and assembled the doors in the folded position using Gator Glue. Here is the finished set of doors, minus their tie down straps, but ready to mount.
As you can see in the photo, how thin the folded set is which is much closer to scale than piling all the plastic doors together, which would have been more than .080 thick, which would be way out of scale. The Eduard doors are time consuming but much closer to scale
As always all comments are welcome.
Rounds Complete!!
