Pastels are great for weathering and can be found pretty cheap. Just scape some off into a tin or contrainer then take a stiff bristle brush and rub the dust on the model. Build it up in corners and nooks and cranies. You can mix and match colors to create any shades. The dust looks just like the real thing and the scale is great.
YodaMan here's my experience with coatings.
I have experimented with coatings - I have applied pastels after dull coating one kit, you can't handle the model after that or you will rub off some of the pastels. Be careful of dust too, so if you can cover it that's a bonus.
I have also tried dull coating over the pastels. I've ruined a couple by going to thick and heavy. So take your time and put on very light coats.
I use Testors Dull Coat.
Weathering for dummies...
slodder
KitMaker: 11,718 posts
Armorama: 7,138 posts
Posted: Tuesday, May 28, 2002 - 11:27 PM UTC
SS-74
KitMaker: 3,271 posts
Armorama: 2,388 posts
Posted: Wednesday, May 29, 2002 - 01:40 AM UTC
I know how you apply chalk to models. (rub some on...) But, how do you get the chalk to stay on? Would a typical clearcoat suffice? Interesting.... most interesting....
YodaMan
Colonel Yodaman Sir, I apply a dull coat first (Gunze), and the pastel chalks seems to sticks on them pretty well...then also thin layer of dull coat afterwards.
herberta
KitMaker: 939 posts
Posted: Wednesday, May 29, 2002 - 02:25 AM UTC
Pastel chalks will stick best to a very matt surface. Gloss or semi-gloss is a problem!
I apply chalk before adding the model to a base, then reapply chalk to the kit and base to blend them together. Once the kit is on the base, I no longer touch the model, and a sealing coat is not necessary. The only problem then is household dust...
Andy
Andy
