Phil.
Jim,Here's where I stand.The ad panel overlap problem has been fixed,Thanks.My only issue now is that the site page is still too wide.I tried bumping up my screen res.(I was at 1024x768)but to get the whole page to fit it made the text size so small it was hard to read.
I do like the new format though,thanks for all you do,Jeff Tucker
Well that was sort of a challenge so I did some work on this tonight actually. For those who have a smaller display you will likely see an improvement if your screen window size is below 1024 pixels. However I am using a cookie to store this screen size value once when you first arrive. So changing your window size after the fact will not change anything (unless you clear the cookie).
I will check this out on my iPad and see how it looks.
Jim
Okay for those wanting a dark background, you can chose that option under Settings > Modify Profile. There is a 'paper' option as well. More of a beige really.
You will need to be LOGGED IN for this option to work however. And it will work across all sites as well.
Jim
Here's some more info,The problem only seems to be with my XP machines.Site works fine with Windows 7 and My Ipad.In order to get a usable page size,with XP,I have to zoom out to 80%,which makes things very small.Jeff T.
I definitely prefer the old page design. When I logged on I said to myself "W-T-F. Where am I???" Sorry, I just don't like it.![]()
Hi Jeff,
XP or Windows 7 shouldn't affect the code change I made last night. And since the cookie didn't exist before last night you shouldn't be able to have 'bad info' about your window size.
Can you send me a screen shot of how the site looks on your XP machine? What browser are you using?
Thanks,
Jim
Jeff,
Ah... I think I know what is happening for you and some others.
Let me do some magic.... [sounds of things getting banged on]
Okay try it now. You will need to hit a second page though like you did this time.
Jim
PS: You had a cached CSS style-sheet with outdated info so I changed the name of the file that is included.
Jeff,
Actually I see the issue on your screen shot. The new feature worked and moved the ads to the right. Except you have your browser window shifted to the right as well. Move your window back to the left and that should be it.
Jim
