The little ‘Ke-Nu’ has been primer coated. This is my first experience with airbrushing Vallejo’s acrylic Gray Primer. I set the air pressure to 12 PSI and tried shooting this stuff straight out of the bottle but the primer came out grainy.
Using the same air pressure settings the model received an overall base coating of Tamiya’s XF-60 Dark Yellow @40%, X-22 Clear @30% and Lacquer thinner @30% (your mileage may very depending on altitude, humidity and temperature).
I then progressively lightened the color to the sun exposed upper surfaces of the model by adding X-57 Buff to the above mentioned mixture. Only the highest upper horizontal surfaces received an even lighter color by adding XF-2 White to the mixture. I have an old model jet airplane that I use for test painting first before apply it to the model.
I don’t pre-shade, as it tends to leave the model looking too dark in this scale. This is especially evident when all of the finishing steps have been applied (filters, oils, and weathering). The primary camouflage colors come next. I’m not exactly certain how to go about using Matthew ‘firstcircle’ Lenton’s toothpaste technique for this purpose so I will have to do a little reading.
Thanks for dropping in, more coming!
~ Eddy
