Hi everyone, a quick post of some pics from the end building & the start of the rubble. Thanks firstly to Jerry & Trevor for the kind comments, looking forward Jerry to adding the mix of Volkssturm with the regular soldiers, showing how desperate the manpower was finally getting in the closing stages...., I've still got quite afew things to add in & around the street, road block, car, cargo truck (probably), MG nest, rubble, traffic lights (maybe), so the dead horse idea might have to be shelved.....
Since I don't need any furniture or fittings to order for the Cafe, I've started here to see how the rubble & debris might look for the rest of the buildings, & then work along the street, picking up any futher ideas or suggestions along the way.
Started off by assembling all the various bits I'd need, broken & crumbled coloured grey plaster, homemade coloured plaster bricks, stained wood pieces, brick wall pieces(made by gluing bricks to a piece of card, painting, plastering between the cracks & weathering), bits of furniture, black powder, window frame & diluted white glue. I divided the area up in half, to do the front of the building first to make sure I was happy with the result, before continuing inside. I glued down a piece of polystyrene to build up the bulk of the debris first.
Was pretty happy with the result, so started on the inside. Firstly covered the polytstyrene with wet plaster to help embed things in, then just randomnly added all the elements, finishing with a coating of crushed bricks & black powder. Used the diulted glue in a spray form to help keep everything in place, once dry repeated the process & also used a little hairspray to also act as an adhesive.
Was happy with the final look, maybe needs afew more bricks since they are the primary component. Noticed that there weren't also many bricks in the rubble in the wooden defences, so will have to add to that alittle more. The sign above the Pharmacy door was taken from a photo of a similar street in Berlin & translates to "Our walls break, but not our hearts".......
Here's how the whole model is now looking so far!!
Awaiting the 'plumbers' to install a bathroom in the 1st floor of the Pharmacy now.....
, & have begun on the figures from the 'Volkssturm', thanks for reading.....
SIMON.
