Okay, mail lady dropped off these, which went into great use.
MUD.
Wet effects, mud, and fresh engine oil add up to this
I used dark streaking grime effects and a brown wash for most of the tank. Gonna have to give it another wash later on. Fresh engine oil was "spilled" onto the rear.
Wet effects created the subtle build up of "water" here and there. It gives the tank a bit of a glossy look, but that's just how it works i suppose. I mixed it with the mud at first, then applied just the water effects after it had dried. It's a learning experience.
Gluing the chassis to the hull (I think that's the right saying, I'm still not too familiar with tank terminology), I sat doing this for five minutes:
There's gaps to be filled, but more mud will do the job. Onto the tracks.
My magic tracks goofed up after they had dried, but it won't be seen once it's on the base. I hope.
Doing mud on the tracks & wheels was basically the same as the everywhere else.
More work, more mud, more tweeking. And finally, the Wirbelwind (bored yet? I am...)
In the process of making it appear as if there was an explosion inside the tank...
Engine oil "blown" out of the engine vents, I just thought it helps portray the mess.
An in-progress shot of the streaking grime. You paint it on (like on the lower bit), let it dry for a few minutes, then take the White Spirit thinner, dab your brush in it, wipe it off a bit, then literally pull and thin it out to your liking(the turret).
So that's where I'm at. Spring break is this week, but I've got surgery Tuesday so I'm not sure how much I'll manage to do. The show I want this to be finished for on Sunday is iffy as well. But that's life, there will be other shows out there. Good night gentlemen.
-Conor
