Hey, Guys
I am looking at the Styrene sheet and strip, there are so many in deferent sizes and shapes, I feel panic already by looking at those....... Can any of you give me a tutorial? I have no idea what I shoud have to get started.
Thank you so much
Jay
Scratch Build 101
hliu24
KitMaker: 798 posts
Armorama: 797 posts
Posted: Wednesday, February 27, 2013 - 06:09 AM UTC
Bluestab
KitMaker: 2,160 posts
Armorama: 1,906 posts
Posted: Wednesday, February 27, 2013 - 08:44 AM UTC
One thing I use is cardstock or posterboard. It can be used to work out templates. And it's thick enough to be taped together to mock-up a shape if need be. Then you trace the template on your styrene.
For cutting thin and medium thickness styrene sheets I often use a photo cutter/cropper. They are used for photography and scrap books. You can pick them up fairly cheap at most hobby and craft stores. I use a Fiskars and I think I paid $10 for it about five years ago.
Hisham
KitMaker: 6,856 posts
Armorama: 6,363 posts
Posted: Wednesday, February 27, 2013 - 09:23 AM UTC
Check out http://www.micromark.com/ for tools, they have some useful stuff. Just look around the different departments.
For plastic, of course Evergreen is the most popular.. but I've also found Plastruct to be very useful because they have some specialty shapes that Evergreen doesn't have.
http://www.plastruct.com/Pages/OnlineCatalog.lasso
Don't feel like you have to buy all the tools at once. Get some of the basic things, then you will accumulate a good collection of tools in time
Hisham
Hisham
gcdavidson
KitMaker: 1,698 posts
Armorama: 1,563 posts
Posted: Wednesday, February 27, 2013 - 10:35 AM UTC
Hey, Guys
Thank you so much
Jay
by one of each!
Seriously, I find the strip more useful than say teh angle, H-beam, and quarter round shapes. There's a rod & tube assortment package that is useful. Each time you go to the LHS, make a point to grab a couple new packs of evergreen and you'll have a decent stock.
I went years cutting my own strips from one & two thou sheet, and still do if I need something not available in the strip size.
JohnTapsell
KitMaker: 227 posts
Armorama: 226 posts
Posted: Wednesday, February 27, 2013 - 11:09 AM UTC
Graeme's right - you can never have enough strip and styrene sheet. I must have 50 or 60 different sizes, widths, thicknesses and profiles of Evergreen strip alone.
I also keep multiple sheets of 5, 10, 15, 20, 30, 40, 60 and 80 thou stryene in stock and replace it as I use it.
The trick is to start with a few basic packs and then build your stock as your skills and confidence grow.
Plans? what are they?. Seriously, although I often refer to plans if they are available, much of my work is done by eye. I build a photo reference of the project I want to build. I'll spend hours hunting the internet (and I mean long hours), collecting walk-rounds, written reference and related data and then build a scrapbook of that material into a single place - either on my PC or more usually printed out and placed in a ring binder.
Be prepared to fail - you suddently realise that what you are building isn't right for some reason. Sure, that project may be scrapped but never lose sight of the fact you will have learnt something from it that can be applied to your next project. The number of times I've built a component, only to realise it's too small or too big and have to start again...
Your greatest assets are time and patience - don't rush a job.
Oh yeah - take short cuts where you can. 'near enough is good enough' as far as my work is concerned. As long as it's straight and true, plus it looks right to me, then that's what matters.
John
John
PedroA
KitMaker: 324 posts
Armorama: 322 posts
Posted: Wednesday, February 27, 2013 - 08:11 PM UTC
Hi Jay.
It's difficult to say you what materials do you need because, to work in scratch, you will need a lot of references and tools.
I think that the best option will be if you show to us your project, the model that you want to make and the model base that you have. With these basic ingredients, I'm sure we could help to you.
You will need to purchase the tools and materials step by step.
Best regards.
Pedro.
Best regards.
Pedro.
Posted: Thursday, February 28, 2013 - 05:37 AM UTC
Tools are expensive!!!
Good tools are _always_ expensive and _always_ worth every penny.
Experienced gained in 50 years from my professional work, from home renos and from modelling has all pointed to one inescapable conclusion:
Always buy the best tools you can afford. Always.
Posted: Thursday, February 28, 2013 - 05:50 AM UTC
Hey, Guys
Thank you so much
Jay
No need to panic. Long before there were available sizes & shapes people were scratchbuilding amazing models.
As long as you can measure, mark and cut parallel lines on sheet plastic, then sheet plastic is all you need. Everything else can be faked or made from sheet plastic.
Once you discover a need for a particular size of premade strip or shape stock, then buy just that. You'll soon build up a wide range of sizes(that still never seems to have exactly what you want at any given moment!) and can build with what you have in stock.
In terms of picking sheet thicknesses to acquire, I use .030" and .040" sheet for the main structure of larger items (hulls, turrets, jigs & fixtures, etc.).
.020-.030" I'll use to make hollow boxes, stowage, smaller turrets, places where I need to be somewhat "scale thickness". Also for surface details and heavy brackets.
.010 - .015" is good for scratchbuilding brackets, mountings, external frameworks, open doors/panels, etc. where you want things to look to scale. I know someone whoh scratchbuilds 1/76 tank hulhs & turrets (with interiors!)from .010" stock, but he's a nutter!
.005" stock is good for surface details and very, very fine & small brackets. Yuo have to be very careful gluing this stuff or it simply melts into a puddle of gooey Tenax.
Use less aggressive liquid cements for the very thin stuff, like Tamiya thick liquid or Testors liquid. Pro Weld, MEK and Tenax are too hot for the thinner (under .020") sheets unless you have serious skills.
For the thicker sheets, score the surface 2-3 times with a knife or scriber and then break off the length you need. Don't try to cut all the way through as yuo can distort things. The edges will always need some clean up, but there it is.
None of this will work the first time (or three) you try it, so practice, practice, practice. Practice making rectangular hollow boxes with lids first and then make some polygonal boxes. It will train you how to measure and fit to ensure the lid fits the box and that the sides overlap properly and everything is square & true.
hliu24
KitMaker: 798 posts
Armorama: 797 posts
Posted: Friday, March 01, 2013 - 12:51 PM UTC
Quoted TextHey, Guys
Thank you so much
Jay
paul,
Thank you so so much for spending time to write out all the detail, these are exactly what I need to know!
jay
hliu24
KitMaker: 798 posts
Armorama: 797 posts
Posted: Friday, March 01, 2013 - 12:53 PM UTC
John![]()
John,
thank you so much, the humvee looks great! Tamiya humvee is one of my most favor humvees.
Jay
hliu24
KitMaker: 798 posts
Armorama: 797 posts
Posted: Friday, March 01, 2013 - 12:57 PM UTC
Thanks alex, Hisham and Graeme and all.
I am Feeling like a baby being taken care of
Jay
Jay
Lonewolf7usa
KitMaker: 312 posts
Armorama: 296 posts
Posted: Friday, March 01, 2013 - 01:02 PM UTC
Hey, Guys
Thank you so much
Jay
Evergreen puts together a mixed bag which has a little bit of everything to get started with. Get this and start out small and as you get a feel for it you can expand boith in plastic and tools. Have fun!!
hliu24
KitMaker: 798 posts
Armorama: 797 posts
Posted: Friday, March 01, 2013 - 01:07 PM UTC
Thank you so much
Jay
Thanks corley
is this what you mean?
http://www.ebay.com/itm/Evergreen-9002-Odds-Ends-/271057268797?pt=Model_Kit_US&hash=item3f1c45b03d
jay
Lonewolf7usa
KitMaker: 312 posts
Armorama: 296 posts
Posted: Friday, March 01, 2013 - 01:25 PM UTC
That's exactly it and like I said start small and work your way up until you get a feel for the scratchbuild and then expand as you go.It's taken me 20 years to aquire the tools I use for scratch building and I am still learn to this day. AND REMEMBER HAVE FUN WITH IT!!!!
hliu24
KitMaker: 798 posts
Armorama: 797 posts
Hi Jay.
Best regards.
Pedro.![]()
Thank you pedro,
I am just getting tired of buying tons after market stuffs.....and they are not alway available.......
This is the device I decided to build from scratch, it is duke anti IED, it was on most the m1151 humvee before MRAP took over.
Picture was taken from Brent's hunvee site, Great site for Humvee, Here is infro
http://www.hmmwvinscale.com/
And this one
I don't remever where it came from.
Pedro, looking forward to your advice.
Jay
hliu24
KitMaker: 798 posts
Armorama: 797 posts
Posted: Friday, March 01, 2013 - 01:27 PM UTC
Thanks again
Jay
mother
KitMaker: 3,836 posts
Armorama: 1,370 posts
Posted: Friday, March 01, 2013 - 07:50 PM UTC
Jay as I said in my first post you don't need to run out and buy expensive tools. Here are some of my scratchbuilds only using the tools I posted.
Good Luck with your project.
Happy Modeling,
Joe
Happy Modeling,
Joe
armouredcharmer
KitMaker: 670 posts
Armorama: 410 posts
Posted: Friday, March 01, 2013 - 08:58 PM UTC
I`m following this thread with interest as i`ve started to scratchbuild little details to improve my kits (i`ve been a modeller for thirty-four years)and this brilliant site just shows how far you can push the boundaries.
A little trick i`ve found is to use the tubular plastic sticks from my kids lollies,they come in a variety of gauges and with a light sanding to help glue and paint stick they make handy poles,exhausts etc.
HTH somebody out there !.
PedroA
KitMaker: 324 posts
Armorama: 322 posts
Posted: Sunday, March 03, 2013 - 02:30 AM UTC
Well Jay.
If you want to make these radio set you don't need a great set of plastic. They are square pieces so, with some plate 0,25 mm and 0,5 mm you will have de necesary. If you purchase these two plates you will have plastic for another projects too. For some pieces in front Evergreen references 100 (0,25x0,5mm) and 102 (0,25x1 mm)
To the handles and cable you can use telephone or electrical wire. I'm sure you have a piece in your house.
To conector some small pieces of plastic stretched using the plastic sprues to your model.
Basic tools:
A cutter, a pencil, a metallic rule, set of mini-drills, set of mini-files, handle for mini-drills, clamps (watchmaker if is possible), fine sandpaper (800 to 2000) and liquid cement.
I think with these basic materials you could to make the two radios.
Best regards.
Pedro.
Basic tools:
Best regards.
Pedro.
