M1A1 Thunder Run - Sgt Booker
KitMaker: 1,437 posts
Armorama: 1,303 posts
Posted: Wednesday, October 09, 2013 - 06:03 AM UTC
KitMaker: 915 posts
Armorama: 797 posts
Posted: Wednesday, October 09, 2013 - 06:39 PM UTC
Very Nice work Robert.
Good attention to detail.
The Abrams is coming along pretty well.
Keep posting the images .
Thanks
Michael
KitMaker: 56 posts
Armorama: 49 posts
Posted: Thursday, October 10, 2013 - 04:56 AM UTC
Posted: Friday, October 18, 2013 - 03:38 AM UTC
Thanks everybody.
I put on the rest of the decals. I only need to do the three red barrel rings. I will have to source three single red Echelon rings. I can mask and paint, but the Echelon decals are so good it is not worth the risk of red paint bleed under the mask, and a crooked mask.
I put a grey/blue filter on but it is not noticeable in this lighting. Before that I did some chipping with a pastel stick, and I also made some scratches with colored pencils on the sideskirts. The filter blended them in, and later I will do some more scratches to show newer ones.
Track end connectors were hung by the real crew on the grab rails, so I sliced a couple off leftover track and then drilled out the holes. I similarly drilled out the holes for the spare track that will go on the bustle rack. I lost the handle for the loader's MG so I made one from a GI WWII shovel - I wound a little tape around the end for the rubber part, and painted the stem. Later I will cut the stem the proper length and glue under the MG hopper.
Next I will do an orange filter, then pin wash and weathering.
Hamilton, New Zealand
KitMaker: 159 posts
Armorama: 158 posts
Posted: Friday, October 18, 2013 - 07:38 AM UTC
looking forward to the finish line, nice
regards Paul
" never interrupt your enemy when he is about to make a mistake"
Napoleon
Noord-Brabant, Netherlands
KitMaker: 291 posts
Armorama: 288 posts
Posted: Friday, October 18, 2013 - 07:53 AM UTC
Looks better everytime Robert!
this build is really motivating to finish mine, after 3years
Arkansas, United States
KitMaker: 11,610 posts
Armorama: 7,843 posts
Posted: Friday, October 18, 2013 - 08:10 AM UTC
Same here. Mine is 90% complete. Think I'll pull it off the shelf, next month.
Posted: Sunday, October 20, 2013 - 07:47 AM UTC
Orange filter applied to the turret, but not the hull or gun barrel yet. Still wet. Noticeable difference.
Later I will pin wash the detail w/ brown and also a wash will be applied as I weather the tank.
Posted: Tuesday, October 22, 2013 - 09:02 AM UTC
Started on some stowage. I am using a lot of the Tamiya stuff and I had to spend a fair amount of time to remove mold seams. I added grab handles to the CIPs and I will soon put the chevrons on them. Crews were issued at least one cooler, but my tank had two, and a drinking cooler as well.
I decided to have a go at making the MRE packets. In my previous build of the OIF M113 I used epoxy putty to make a couple that were on the track floor. I wanted to have an easier way, and more importantly, something that would be more consistent in size and shape. I decided to use lead foil wrapped around Evergreen strip of 1.09 x 2.84 mm. After wrapping the plastic strip in foil I pinched the ends and voila. I will put one or two in the spare roadwheel on the roof, and I probably will show an MRE box partially opened with a few packets spilling out.
I finished with the barrel rings and I placed the spare tracks on the bustle rack ends. I went to the effort of slicing the track horn off so I could reglue it at an angle as it is in real life when they unbolt it and attach it. I sliced the drilled out horn and reglued the half around the bustle rack rod. I then filled any gaps with Tamiya putty. It seems like too much effort, but what the heck...
KitMaker: 139 posts
Armorama: 136 posts
Posted: Monday, October 28, 2013 - 02:22 AM UTC
Very nice... Between the tracks, and the weathering, and the little details, like the civvie GPS on the .50 cal mount, it really pops. I like the orange filter effect. Initially it seems a bit much, but I can see where the look is headed, and the effect it had on the sand tone. Looking forward to more!
Take care,
Larry
Posted: Monday, October 28, 2013 - 08:17 AM UTC
Thanks Larry. There still is a ways to go on the painting. A brown wash along with a dark brown pinwash. Then everything will get dusted at the end.
Some progress:
Stowage in varying degrees of completion. I mounted the jerrycan racks and one CIP. The other CIP and exhaust deflector will go on at the very end since they will be dangling from the turret due to the accident.
Close-up of the jerrycan rack. The kit is incorrect in how they hang. An 'L' shaped bracket was welded to the back on both ends. You can see one here pretty well. Space has to be left so it can hang over the grab rail.
The CIPs need grab handles placed near the top sides. In turn, they were tied to the grab rails.
I tried to do some writing on the MRE packets. I think they look ok from a normal distance.
KitMaker: 17,694 posts
Armorama: 13,742 posts
Posted: Monday, October 28, 2013 - 11:31 AM UTC
Looking good Bob. I like how you did the damage. On the MRE bags, I would print some labels for them on computer decal paper in dark brown.
Showcase
Posted: Tuesday, October 29, 2013 - 12:10 AM UTC
Your work continues to impress.
I agree, with Bob concerning the MREs. I doubt that they would be legible, in 1:35 scale.
Posted: Wednesday, October 30, 2013 - 12:59 AM UTC
I appreciate the comments, as always. As far as making decals, that is something I am not up to at the moment. I agree the packets would look better with them, but I think they are OK at this time. Only a couple will be truly visible - I will pick the best ones to show on top.
Last night I did some pinwashing. You can see where I have not done it yet on the left rear deck. I will likely go back over some areas with a clean, wet brush and remove any areas I think are too heavy.
Posted: Friday, November 01, 2013 - 09:53 AM UTC
Playing around with stowage. There will be a tarp over part of it.
Scratched a bucket and I plan on showing some CDs spilling out of a CD storage carrier. I did not exactly get center holes for all of them but it is very easy to punch out more if I need them. I used that party confetti stuff. I plan on only showing two or three CDs.
KitMaker: 915 posts
Armorama: 797 posts
Posted: Saturday, November 02, 2013 - 09:31 PM UTC
Nice work Rob,
The bucket and cd's look good and very
small to work with.
Michael
Posted: Monday, November 04, 2013 - 06:14 AM UTC
I may ditch the CDs. They are not coming out the way I had hoped. The act of drilling the hole damages the silver. I am experimenting with getting an image online and reducing it and printing it out. It won't have the pow factor of the silver confetti, but it may still look good, and more like a CD in the end.
Today I did the tow cables. The kit cables aren't exactly like real cables, but since they fit the cable ends the best I went with the instead of AM stuff I have lying around. For the rear cable I had to leave the cable end off until I threaded it through the tow pintle. I also had to slice off one bolt from each shackle to get the cable end to fit into the shackle. I then used Grandt Line bolts as replacements. You can see I have not pinwashed the cables or shackles just yet.
Tow bar attached too. I pinwashed it but still need to do an overall wash/filter and then highlight.
Later I will put two razor wire coils over the towbar.
I don't like the look of one of the fuel caps in front so I will play around with some thinner to remove most of it.
KitMaker: 291 posts
Armorama: 288 posts
Posted: Monday, November 04, 2013 - 06:50 AM UTC
awesome Robert!!! it's getting better everytime
You got me motivated a while ago with this build to finish my A23 Saddam diorama!! stay tuned for a update soon
Posted: Monday, November 04, 2013 - 07:35 AM UTC
I can't wait to see your finished. Everything from the figures to the base to the tank itself were sensational. It's been too long sitting in that unfinished state.
Posted: Tuesday, November 05, 2013 - 01:35 AM UTC
Have you considered using sequins, for the cds? I think you can find some small enough. I believe my grandmother used them, for dolls she made.
Posted: Tuesday, November 05, 2013 - 12:49 PM UTC
Posted: Saturday, November 09, 2013 - 09:15 AM UTC
Wisconsin, United States
KitMaker: 584 posts
Armorama: 525 posts
Posted: Saturday, November 09, 2013 - 03:19 PM UTC
looks really good! nice work, nice detailing! and excellent weathering job.
Posted: Sunday, November 10, 2013 - 01:51 AM UTC
You are taking it to the next level. I can't say this enough. Truly superb work!
KitMaker: 116 posts
Armorama: 110 posts
Posted: Sunday, November 10, 2013 - 07:41 AM UTC
Nice work, the hog looks excellent and it's really useful having descriptions on what you did and how. Thanks for sharing.
